Old 02-04-2011, 06:11 PM   #21
Ed Wright
Ed Wright's Avatar
Default Re: AHFS Updated
"The class review revealed that K/SA had a class/engine average for the combination in question of 1.101-second under, therefore surpassing the 0.850-second-under requirement and signaling a horsepower adjustment for all 305/215/241 FI Camaros."
Sounds like 1.01 trigger, and the average has to be faster than .85 under for a hit.
Ed Wright 4156 SS/JA
Old 02-04-2011, 09:14 PM   #22
Jeff Teuton
Liked 325 Times in 50 Posts
Sounds like everyone is getting the drift. Also a racer that runs two runs between 1.00 and 1.19 at the same event triggers the review.
Jeff Teuton 4022 STK
Old 02-04-2011, 09:35 PM   #23
Toby Lang
Liked 2 Times in 1 Post
Except when they do it only in qualifying. Say a racer runs 1.05 under and 1.03 under during qualifying, that only counts as one trigger since only the 1.05 under run shows on the final qualifying sheet.
-Toby
Old 02-04-2011, 09:40 PM   #24
Ed Wright
Ed Wright's Avatar
I just keep learning about this! Last year I was told 1st round of class was the only class round that counted. That never did make sense to me. Also did not know only the fastest qualifying time counted. Used to be just Farmer's call. LOL.
Old 02-04-2011, 09:55 PM   #25
Liked 1,864 Times in 422 Posts
Originally Posted by RPinoski1 View Post
Bob,
For some unknown reason once a combo gets a new HP Rating all previous runs for that combo are wiped out. The data collecting starts all over at the new HP rating. My thinking is the runs should continue to be gathered and be reviewed at the end of the year to see if the " possible runaway combo" is still a running away. LOL
The data from before the hit is irrelevant. Once it has been hit, the factor has changed, and the previous data no longer matches the current combination. How would you accurately correlate previous data to a car now running heavier, or in a different class, or both?
Old 02-04-2011, 10:25 PM   #26
Ed Wright
Ed Wright's Avatar
Makes perfect sense.
Old 02-04-2011, 10:43 PM   #27
I've never made perfect sense in my life.
Old 02-04-2011, 10:48 PM   #28
Ed Wright
Ed Wright's Avatar
I think you usually do.
Old 02-04-2011, 11:28 PM   #29
Chad Rhodes
perfect change maybe, but never perfect sense
Chad Rhodes 2113 I/SA
Old 02-05-2011, 11:51 AM   #30
RPinoski1
What I'm saying is:
An auto hit should also trigger a rewiew of the class average at that time before the data is thrown out.
Soft combos are exactly that "SOFT"
I don't care how hard you work on your car. Blah Blah Blah
The fact remains a "soft combo" will still be at the top of the heap until it is reeled in like the tried and true combos.
It is my experience that the "Soft Combos" are usually in the wrong class to begin with. based on carb size, head cc's, valve size, cubic inches etc.
My question to all.......
Should any combo ever be rated lower than the factory HP rating?
RPinoski1 is offline   Reply With Quote
