Liked 5 Times in 4 Posts
noticed in the IHRA rule book, that they were allowing the relocation of the battery to the trunk, is that a IHRA only rule now? or is NHRA also allowing that in Stockers now?
Liked 3 Times in 1 Post
Speedy, you can ADD an additional battery to the trunk area. You can not move the battery from the original location to the trunk in NHRA. Exempt of course are cars that came from the factory with a trunk mounted battery.
Wade |
Liked 279 Times in 68 Posts
Wade's right for NHRA
Greg Hill 4171 STK |
Liked 333 Times in 180 Posts
plus BOTH batteries MUST be the same size if I'm not mistaken
Liked 136 Times in 49 Posts
You also have to add a disconnect switch if you have the two battery set up.
Liked 23 Times in 13 Posts
So does everyone run a hollow case battery up front ??
I wouldnt suggest it Im sure Tech is wise to that too!!!! comp
if you add 2nd same size battery and disconnect switch does switch just have to cut off fuel and ignition or everything- cable all the way to rear and back up front??
yup. Wiring mine up today, lol.
Chad Rhodes 2113 I/SA |
