Old 02-11-2011, 07:56 AM   #1
Speedy Peets #4103 I/SA
Liked 5 Times in 4 Posts
Default battery location
noticed in the IHRA rule book, that they were allowing the relocation of the battery to the trunk, is that a IHRA only rule now? or is NHRA also allowing that in Stockers now?
Speedy Peets #4103 I/SA is offline   Reply With Quote
Old 02-11-2011, 02:38 PM   #2
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Re: battery location
Speedy, you can ADD an additional battery to the trunk area. You can not move the battery from the original location to the trunk in NHRA. Exempt of course are cars that came from the factory with a trunk mounted battery.
Wade
Old 02-12-2011, 11:34 AM   #3
Greg Hill
Liked 279 Times in 68 Posts
Wade's right for NHRA
Greg Hill 4171 STK
Old 02-12-2011, 11:44 AM   #4
FED 387
Liked 333 Times in 180 Posts
plus BOTH batteries MUST be the same size if I'm not mistaken
Old 02-12-2011, 12:22 PM   #5
novassdude
Liked 136 Times in 49 Posts
You also have to add a disconnect switch if you have the two battery set up.
novassdude is offline   Reply With Quote
Old 02-12-2011, 02:18 PM   #6
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
So does everyone run a hollow case battery up front ??
L78 Nova is offline   Reply With Quote
Old 02-12-2011, 08:37 PM   #7
FED 387
I wouldnt suggest it Im sure Tech is wise to that too!!!! comp
Old 02-13-2011, 09:36 AM   #8
Richard Muhlenhardt
if you add 2nd same size battery and disconnect switch does switch just have to cut off fuel and ignition or everything- cable all the way to rear and back up front??
Richard Muhlenhardt is offline   Reply With Quote
Old 02-13-2011, 12:07 PM   #9
Chad Rhodes
yup. Wiring mine up today, lol.
Chad Rhodes 2113 I/SA
Old 02-13-2011, 01:12 PM   #10
novassdude
when the switch is turned off it must kill every thing.
