Old 02-14-2011, 01:59 AM   #1
Mike Schwartz
Liked 248 Times in 89 Posts
Default 2012 Fiat 500
I examined one of these at the NC International Auto Expo this weekend. Quite a nice little car. It would be interesting to see if Chrysler would want to attempt to get it accepted in the Classification Guide so it can run Stock.
Class Factors (Factory specs)
5M: 23.26
6A: 24.05
2012 FIAT 500 SPECIFICATIONS
ENGINE:
1.4-LITER DOHC 16-VALVE MULTIAIR® INLINE FOUR-CYLINDER
Bore x Stroke
2.83 x 3.31 in. (72.0 x 84.0 mm)
Valve System
Belt-driven, MultiAir, 16 valves, hydraulic end-pivot roller rockers
Fuel Injection
Sequential, multi-port, electronic, returnless
Construction
Cast-iron block with aluminum-alloy heads and aluminum-alloy bedplate
Compression Ratio
10.8:1
Power (SAE net)
101 bhp (75 kW) @ 6,500 rpm (73.8 bhp/L)
Torque (SAE net)
98 lb.-ft. (133 N•m) @ 4,000 rpm
Max. Engine Speed
6,900 rpm (electronically limited)
Fuel Requirement
87 octane (R+M)/2 acceptable
91 octane recommended
DIMENSIONS AND CAPACITIES(B)
Wheelbase
90.6 (2300)
Ground Clearance
4.1 (104.0)
Drag Coefficient (Cd)
0.35
Curb Weight, lb. (kg)
2,350 (1068.1)—5-MTX
2,430 (1104.5)—6-ATX
SUSPENSION
Front
MacPherson suspension, coil spring with twin-tube shock absorbers and stabilizer bar—Included with 500 Pop and 500 Lounge
Sport-tuned shock absorbers and springs—Included with 500 Sport
Rear
Rear twist-beam axle with coil springs and twin-tube shock absorbers—Included with 500 Pop and 500 Lounge
WHEELS & TIRES
500 Pop & 500 Lounge
15 x 6.0 steel or cast-aluminum wheels
185/55R15 BSW all-season tires
500 Sport
16 x 6.5 cast-aluminum wheels
195/45R16XL BSW all-season tires
Old 02-14-2011, 04:58 AM   #2
bill dedman
Liked 6 Times in 4 Posts
Default Re: 2012 Fiat 500
Don't see much hope for it in Stock, but it would make one hell of a Pro Stock platform (That thing got a Hemi in it???)
Bill
bill dedman is offline   Reply With Quote
Old 02-14-2011, 05:43 AM   #3
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
being a fiat, better stick to 1/8 mile tracks, i don't think it could run the whole length of a 1/4...
Old 02-14-2011, 11:15 AM   #4
Chris Barnes
I could drive one into the back of my wagon and bring two cars to the track on one trailer!
Chris Barnes
Stock 6621
Chris Barnes is offline   Reply With Quote
Old 02-14-2011, 11:20 AM   #5
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: 2012 Fiat 500
Looks like you need two of them. One for each foot just like roller skates !
Old 02-14-2011, 12:43 PM   #6
Bobby DiDomenico
Liked 101 Times in 52 Posts
5M: 23.26
6A: 24.05
2012 FIAT 500
My associate says that is "one very unattractive looking car."
Old 02-14-2011, 02:14 PM   #7
Steve Williams
I was gonna say the same thing but with different words. FUGLY
Steve Williams is offline   Reply With Quote
Old 02-14-2011, 02:22 PM   #8
James L Miller
Liked 25 Times in 16 Posts
How about a Drag Pack version with the Viper V-10 rated at 300 HP, mid-engine mount with a ZF transaxle?
Mopar 2 Ya!
Old 02-14-2011, 02:40 PM   #9
Dan Bernay
Liked 13 Times in 8 Posts
Hope winter ends soon!
Cabin fever is making you guys NUTS!
Old 02-14-2011, 02:47 PM   #10
X-TECH MAN
Banned
Dosent that run K/SA?
