Old 02-18-2011, 08:34 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question Mikronite
How many of you have tried the Mikronite on your ring and pinion?
How much cost?
What kind of gain (ET or MPH??
Was it worth it??
MEXJOE is offline   Reply With Quote
Old 02-21-2011, 11:59 AM   #2
MEXJOE
MEXJOE's Avatar
Default Re: Mikronite
WOW OVER 300 LOOKERS & NO REPLY.??
Must be good stuff??
How much cost?
Was it worth it??
Old 02-21-2011, 12:16 PM   #3
Paul Hellenberg
Mikronite works well,but they were either part of Crane or bought Crane. Not sure if the new Company still does that or not.
Paul Hellenberg
3881 SS and STK
paul@hellenberg.us
Paul Hellenberg is offline   Reply With Quote
Old 02-21-2011, 12:21 PM   #4
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
http://finishedracing.com/
330 858 1842
Bob Pagano A/SA
Old 02-21-2011, 01:42 PM   #5
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Kent cigarettes had a micronite filter.The early ones (1952-56) had asbestos in them.
Now back to the subject.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 02-22-2011, 11:24 AM   #6
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
call Jim Bailey, he makes ring and pinions look like jewels, 330-858-1842. Dyno
Dyno is online now   Reply With Quote
Old 03-20-2012, 07:49 PM   #7
joelster
Originally Posted by Bob Pagano View Post
That's cryogenic. I can see how that would make a ring and pinion stronger, but does it make the car faster? Does cryogenically treated ring+pinion gears reduce friction?
Some of you guys are tight lipped in here, lol.
Have any of you experienced positive results from switching to a Mikronited ring and gear setup? How much did you pay? Where did you get the process done?
joelster is offline   Reply With Quote
Old 03-21-2012, 11:29 AM   #8
Reed Granrt
Cryogenics has really been around for quite some time in industry. It really didnt make it into racing until Indy and Nascar and now drag racing. Its first and foremost use was in stress relief although certain materials can see a change in strength. It would be very hard to show an increase or decrease in friction as it wasnt designed for that. It will normally result in increased tool life expectancy. Good example is drill bits and endmills. Really helps on any thing that gets shock (rear gear, trans gears). Your savings will be gears that will last much longer.
racear
Reed Granrt is offline   Reply With Quote
Old 03-21-2012, 11:57 AM   #9
Myron Piatek
Liked 138 Times in 51 Posts
Thumbs up Re: Mikronite
Jim's website shows that he can do cryo, the "Finished" surface treatment or both!
I've been getting gears done for a few years and they appear to be lasting longer. I was not in a position to do back-to-back tests with the "Finished" surface treatment, but others I know have had positive responses. It would stand to reason that a highly polished surface would at least have less resistance moving through oil over OEM machined and coated surfaces. A smoother surface would also tend to reduce friction. I wouldn't be wasting my time on it if I didn't think it was beneficial.
Old 03-21-2012, 12:14 PM   #10
BlueOval Ralph
Banned
A smoother surface would also tend to reduce friction. This may not be 100% correct you may not want a super fine finish as it may not let your ring & pinion retain the lube the parts don't like to run dry.
BlueOval Ralph is offline   Reply With Quote
