Old 02-27-2011, 07:32 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1966-70 Square Port Heads, 396 & 427 Blocks
3919840 heads F-17-8 & F-18-8 rebuilt $1500
3919840 heads J-31-8 $1250
3919840 heads J-31-8 and K-4-8 slightly ported $1100
3919840 heads A-22-9 rebuilt $1750
3919840 heads C-25-9 $1250
3964291 single head D-23-70 $600
1968 396 4 bolt MQ coded standard bore block E-21-8 $1250
1968 396 4 bolt CE coded warranty block 30 over F-10-8 $1500
1969 396 4 bolt L89 block J-7-8 with JJ code 1 of 311 camaro blocks $3000
1969 396 4 bolt L89 block J-14-8 with KG code 1 of 400 chevlle blocks $3000
1968 3919842 aluminum heads 6-15-67 (crack) 10-29-67 (milled) $1500
1969 3919842 aluminum heads rebuilt 10-24-68 & 6-2-69 stock $3500
6223 steel crank freshly turned 10 under on mains 20 under on rods $300
3873858 heads rebuilt D-18-6 & E-2-6 $2500
3873858 heads F-13-6 & F-17-6 $1750
3904391 heads J-10-6 $3000
1967 427 4 bolt standard bore block dated H-18-6 $6000
330-770-2517 for any questions or pictures needed and can ship if you cannot pick the parts up.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
