Is anyone aware of availability of a .050 under bearing for the 455 Olds rods?? If not, is there a suitable undersize that I can grind my crank to and use a different bearing??? Thanks.
Marvin Robinson 3188 STK/SS |
Liked 1,923 Times in 432 Posts
Marvin, what are you trying to do? Repair a bad journal?
Alan Roehrich 212A G/S |
You got it, #5 rod took the journal down .004 when it spun, and the crank is already .040 under (.013 offset). I'm getting a lot of negatives trying to get the crank welded..... if I have to replace it, can I use the Eagle cast crank in stock??
Nope. Aftermarket crankshafts are not legal in Stock. I know Olds cranks are getting hard to find. At least good ones are. So are blocks.
Liked 66 Times in 37 Posts
Do you really need .013 on a 455 Olds??? HAHA If it were SS you could offset grind a 425 crank and use 454 bearings.
72 cutlass |
I don't see any real advantage to offsetting by .013, but that's the way the motor was when I bought the car. If the crank needs to be turned .010 or .020 under, might as well get the minuscule stroke advantage, too. (Note: in the Olds, most stock blocks have the pistons about .030 down in the hole, the offset will reduce the amount you have to deck the block)
Liked 536 Times in 110 Posts
Marvin: When the crank is stroked .013", it is also "indexed" as well, insuring that the rod throws are truly 90° apart. It shouldn't be too hard finding a suitable replacement crank, I'm not hoarding all of them.
Jim Kaekel 3836 STK |
Good point, thanx for the info, Jim. I think I've got a line on a couple spares (I want to build a spare short block, too. Shure would be nice to just be able to buy an Eagle cast crank.
