Old 03-10-2011, 12:38 AM   #21
CMcAllister
Liked 928 Times in 263 Posts
Default Re: window net requirments
If my memory is correct, years ago the rule book did indeed say that you needed a net if you had a cage, regardless the ET. Somewhere along the line, that was changed to the current wording.
Old 03-10-2011, 02:26 AM   #22
JP
JP's Avatar
IF you have a window net, don't install it to tight...in case of fire it will shrink and you will not be able to release the buckles, that's bad!
JP is offline   Reply With Quote
Old 03-10-2011, 06:37 AM   #23
GTX JOHN
Liked 2,512 Times in 701 Posts
I have been racing my Demon for the last fifteen years plus with a full Chrome Moly Cage. It has a current chassis cert. on it and a ETI on it. I, have raced SS/JA and KA plus E/SA to G/SA.......has not had net in it since 1995 (175 Div./ Nat. Races) without an issue.
Old 03-10-2011, 08:56 AM   #24
danny waters sr
danny waters sr's Avatar
Thumbs up Re: window net requirments
Chassis cert don't have anything to do with the window net. (chassis only)
Old 03-10-2011, 09:29 AM   #25
Ed Wright
Ed Wright's Avatar
There ya go!
Ed Wright 4156 SS/JA
Old 03-10-2011, 09:32 AM   #26
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Rulebook section 6.3 states "any car REQUIRED to have a roll cage must have a window net"
The key word is required. .....If you are quicker than 9.99 or faster than 135 mph, you need a cage, AND a window net. ....Slower than that ,you dont need the net.
Old 03-10-2011, 12:50 PM   #27
Mike Pearson
Mike Pearson's Avatar
Liked 1,982 Times in 597 Posts
Better off to be safe than sorry. I would run the net.
Mike Pearson 2485 SS
Old 03-10-2011, 01:03 PM   #28
Phillip marvetz
Phillip marvetz's Avatar
Originally Posted by Dinsdale View Post
My understanding is that a cage does not automatically require a net. If it did, why aren't you required to have the rest of the safety gear a 9.99 or 135 triggers as that's when you need the net?
In the same vein though, I've seen tech tell people with a roll bar in a car that runs high 11's they have to run a 5 point harness. Take the bar out and your 40 year old seat belts are good to go. I really can't figure that one out.
I have a roll bar, Aftermarket seat and stock belts in the Duster my wife drives, I have been questioned a bunch of times in tech about not having a harness but they always end up letting us thru. I should probably put a harness in it for her but I'm to cheap to throw away new belts every two years for no good reason. Those stock belts are 38 years old now and have never been used, LOL.
2009 V/SA Record Holder
Old 03-14-2011, 07:17 PM   #29
Darrin Christen
Darrin Christen's Avatar
Not trying to jack this thread, but if the car has a cage that was previously cerified and is not required to have a cage do you still have to get it certified every 3 years?
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 03-15-2011, 06:44 AM   #30
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
No....... At least, that is my interpretation of the rules.
