Old 03-19-2011, 09:08 PM   #71
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
Default Re: Limited time offer!
Billy,
I must have been thinking of your "offer" while I was at Indy last year. I could be psychic.
ID:	6545   Click image for larger version
ID:	6546   Click image for larger version
Steve Jackson
Old 03-19-2011, 09:30 PM   #72
Doug Blackley
Doug Blackley's Avatar
This could turn into a Woodstock like experience for the Class racers. You may need a bigger kitchen.
Doug Blackley 1697 STK
Old 03-20-2011, 07:48 AM   #73
Billy Nees
"Don't take the purple acid!" (we're saving that for the heads and intake)
Billy Nees 1188 STK, SS
Old 03-20-2011, 09:25 AM   #74
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Billy, Donny H said it was "OK" to drink.....
Bob Bender 144 O/SA
Old 03-20-2011, 09:25 AM   #75
Rsmith38
Liked 28 Times in 15 Posts
Billy, while I can't afford to go all the way to PA for your Class, I do have a 6 cyl Jeep (1.5 under IHRA index) which could be available if one of those Pasty White Hands guys has a big checkbook and doesn't qualify for admission. I could even ENHANCE him with a new Engine and Trans an make him go maybe 1.75 under (probably only 1.4 inderNHRA R/SA) Might not work for some drivers, no electric shift, etc.
Good luck with the Seminar.
Rsmith38 is offline   Reply With Quote
Old 03-20-2011, 01:04 PM   #76
Liked 10,820 Times in 2,249 Posts
Frank, do you have a base plate to shaker adapter for the 225 slant six in the E body ???
Thanks, Larry
Old 03-20-2011, 02:42 PM   #77
treessavoy
Liked 4 Times in 4 Posts
I'm seriously starting to look at the slant six, 4 sp Valiant in my yard as a fall back position.....wonder if it will wheelstand with caltracs?
JimR
B/SA 1964
Jim Rountree
Old 03-20-2011, 08:00 PM   #78
Frank Castros
Liked 2,741 Times in 967 Posts
Thanks, Larry
Larry,
The Slant Six Challenger can be run with the T/A hood but the Cuda cannot run the AAR hood as you very well know.
The Slant Six Shaker stuff is very hard to come by. Jeff Teuton might have some stuff in his shop.
Old 03-20-2011, 11:21 PM   #79
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Larry,
Larry, In 1971 if you run the aluminum head you can run the SIXPAK and I'm pretty sure that the adapters are all the same in a B or E body.
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
Old 03-21-2011, 04:19 PM   #80
5413ss
thought this may fit in with what you are referring to:
http://www.copart.com/c2/homeSearch....SEARCH_RESULTS
someones next project!
Patrick
Patrick McGrath
5413ss is offline   Reply With Quote
