Old 03-20-2011, 07:04 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 L89 #3919842 Aluminum Heads Rebuilt & L89 Blocks
1969 L89 396-375HP aluminum cylinder heads dated 10-24-68 and 6-2-69. These heads are all stock with no porting or milling and have the stock 2.19 intake and 1.84 exhaust vavles just like the factory set them up. Won't find a nicer set and are built to stock specs ready to bolt on and go $3500. 330-770-2517 for any questions or pictures needed.
I also have two real 1969 L89 blocks. First one is out of a camaro and is standard bore the second one is out of a chevelle and is 30 over. The camaro block is dated J-7-8 and front pad T1014JJ and is 1 of 311. The chevelle block is J-14-8 and front pad T0527KG and is 1 of 400 built. I want $3000 each on the blocks. Can ship if you cannot pick them up.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
