Old 03-21-2011, 09:12 AM   #51
Greg Hill
Liked 279 Times in 68 Posts
Default Re: 2011 4.6 3 valve Ford Ok'd for stock
Jim, you got that dead right.
Greg Hill 4171 STK
Old 03-21-2011, 09:44 AM   #52
Ed Wright
Ed Wright's Avatar
Originally Posted by GUMP View Post
The 275 HP for my Firebird was dead honest. The problem is that the HP numbers in the book are factors not HP numbers.
The cylinder head work they can hide in the aluminium LT1 heads is a big factor there. Hang one out of the GM crate, or out of a car, on an engine dyno, they won't make anywhere near their stock hp factor. Thatr's the big reason the S & SS factors are so different. The SS heads aren't all that much better than a good set of Stock Eliminator heads. Put a set of actual stock castings on a good running LT1 Stocker and see how fast it is now.
Ed Wright 4156 SS/JA
Old 03-21-2011, 10:05 AM   #53
BlueOval Ralph
Banned
Every body is bitichn about the Ported Ford Heads for Stock on this 5.0 235 hp combo! Does anybody understand it has been legal for the Chevys, if anybody choses to run the Z06 427 it has been in Comp Guide since 2006 Not sure if NHRA even knows that the heads are CNC Ported from the Factory!!!!!! BTW with Titanium Rods and Intake Valves
BlueOval Ralph is offline   Reply With Quote
Old 03-21-2011, 10:09 AM   #54
Ed Wright
Ed Wright's Avatar
Doesn't matter Ralph, the Z06 has an honest hp rating. Wouldn't be competitive with the new Ford & MOPAR stuff. I don't see how that matters anyway, as long as the hp rating is correct. Nothing else matters.
Old 03-21-2011, 12:03 PM   #55
goinbroke2
Liked 405 Times in 158 Posts
Take a step back for a second.
If you were going to build a car today, what would you look for?
Two choices
1) Your favorite car. (ford/chev/dodge)
2) Low factor car of your brand.
3) Low factor car of any brand.
Why do you run the car you do now?
Bought it new in 72 or was the fathers or type of car you first got laid in.....etc..etc
What if, all the manufacturers started filling the class guide with new cars, way underrated..what would happen?
That's right, you'd see a lot more cars like the ones in your neighbourhood on the track.
Easy to run the index by getting to minimum weight, gears,converter and slicks.
Manufacturers get better exposure of their newer cars, sell more new parts from others who street drive the same vehicles, kinda like it was in the 60's eh?
You decide if that's better or worse.
One issue is all the old iron that is passed by or rendered obsolete. Maybe a 20yr cut off for the guide to keep the manufacturers happy and a "modified" class for over 20yo?
Yes I know, your ready to firebomb me, but wait.
If I was going to build a car today I would go for option 2 because option 1 is always stupid expensive and most of the time not competetive without real deep pockets.
So, I go through the guide and find a 1962 widget that's 400 cubes and 122hp. GREAT!
Now where the heck do I find a 62 400 widget? hmmmmm
Ok, a 2009 widget with blower and 4valves with 122hp. GREAT!
Now where do I find a 09 blown widget? In every freaking autotrader/buyerflyer/local paper.
I'll pick that up tomorrow and order a converter/slicks and gears and run the index. Then, as I pick up I'll be factored accordingly.
(and if I do a stocker build on it first, I'll be -.120 out of the box. That will be hit sooner)
Not the perfect solution, I know. The thought of 68CJ's and Hemi's being relegated to a modified or nostalgia class is depressing. The upside is, there is still S/SS racing 5 years from now. AND, if done right, it would showcase CURRENT Stock vehicles at the dealership.
Old 03-21-2011, 12:24 PM   #56
novassdude
Liked 136 Times in 49 Posts
[QUOTE=
[/QUOTE]
One problem with your plan most of the new cars can not be bought add a converter and slicks and run the index. Because most of them are not in the guide with the motor that came in them.
novassdude is offline   Reply With Quote
Old 03-21-2011, 07:51 PM   #57
goinbroke2
I'm saying if all manufacturers filled the guide with all their cars at low rating for their own purpose. (the purpose of getting lots of new/current cars in the limelight)
Pick any car/any manufacturer and set the factor at .5hp per cube. (I think the start out for most was .56-.60 except for ringers)
150 cubes = 75hp
200 cube = 100hp
and so on.
Suddenly a 355hp flex with awd rated at 175hp is kicking ***. Easy to build, easy to run index, ALL STOCK PARTS with the exception of converter etc. Hey, how about make a pure stock class with really low factor, might accomplish the same thing (not the current IHRA pure stock, pure stock with really low factor)....351C 71 mustang is 294hp in stock but 175hp in pure stock? New camaro at 175hp in pure stock? Think there wouldn't be a ****load of NEW cars being built? LOL!
