Guest
Posts: n/a
Is it better to use the forward and reverse clutches that are grooved or smooth?
Scott, there are low/reverse clutches, high gear clutches, and a low gear band, in a PowerGlide. There are no forward clutches.
That being said, I've had the best luck with Alto Red Eagle clutches, and the blue Kolene treated steels with the "turbulator" holes. In MOST applications, the regular grooved Raybestos clutches work fine. But the Alto stuff is more aggressive, and will hold up in bad situations where other stuff might give up. I prefer the Kevlar band, but many of the aluminum drums on the market are not fully heat treated, and not hard anodized. A Kevlar band will hurt those drums, and they're better off with a softer red band.
Alan Roehrich 212A G/S |
Guest
Posts: n/a
Sorry, I have a habit of calling the high gear clutches forward clutches. Thanks for the info. Where do you get the steels from?
Guest
Posts: n/a
Where is the best place to order from?
Liked 99 Times in 60 Posts
this company is a good trans parts source
http://www.tsr-racing.com/ Also, He wrote/sells a great Powerglide reference book.
Larry Woodfin 471W |
Guest
Posts: n/a
Thanks! I just ordered everything I needed from tsr.
