Old 03-30-2011, 01:06 AM   #1
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Ahfs
Wow.Kudos to NHRA and the revised AHFS system.They're handing out horsepower like a politician hands out patronage jobs.The Dodge D-150s just got 18 HP.There's hope that the out of whack combos,if they're pushed,will get the hits they deserve.
See,and everybody tells me I only get on here and bash NHRA,right Jack?
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-30-2011, 08:38 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: Ahfs
Uh, isn't that the truck that got DQ'd. I'm all for adjustments but how do you hand it out to a combo that got bounced? I know I read somewhere it was an issue with a grille or something cosmetic, however DQ'd is DQ'd correct? Of course I could be wrong on this, just didn't see any other 86 dodge truck combos on the list. Maybe there needs to be some clarification on this. IMO. Joe
Joe Buchanan SS/BX 3117
Old 03-30-2011, 09:46 AM   #3
art leong
Default Re: Ahfs
DQ is DQ it should not count. If there was enough of a reason to disqualify him. wether they thought it was performance oriented or not.
Did Sorensons run count when he was light?
Seems like politics as usual for nhra no changes.
Unless the racer himself decided to bring up an illegal modification after they made the run to avoid the hit. Like draining the water to make the car light.
Art Leong 2095 SS
Old 03-30-2011, 09:54 AM   #4
Chad Rhodes
Default Re: Ahfs
the problem is that these hits will be few and far between after a short while. Most of the hits so far have been very accidental or possibly due to a lack of understanding of the new system( no good explanations for the Skillmans) . The new cars that have been hit won't be fazed potential wise , but could possibly be moved out of stock eliminator. If you remember when these changes were implemented, Jeff Teuton said that it would end up affecting the older combos worse, and I think he sadly may be right. I can see more guys hurting their average in the upper classes trying to catch a DP or CJ, than i see CJs or DPs getting hit in qualifying. A small hit (from average, not instant hit) for the new cars is going to be much less detrimental than a small hit (from average) on say a 396/375.
Prime example is Bob Shaw's caddy. Its even more deadly than the some of the new cars (after what we saw at Pat's CIC race), but i bet it doesn't get hit. Bob is smart.
Chad Rhodes 2113 I/SA
Old 03-30-2011, 10:55 AM   #5
jmcarter
jmcarter's Avatar
Default Re: Ahfs
I'm with Art on this one...1000%; that said I think GTX John has more important things to concentrate on right now so I would vote for just letting this whole thing rest.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-30-2011, 11:14 AM   #6
buzzinhalfdozen
Default Re: Ahfs
I agree with letting it rest, heck I don't even run Stock, however I'm confused on the issue of a DQ'd entry getting HP. I'll admit I'm not quite sharp enough to fully comprehend the ins and outs of the AHFS just seems odd to apply it this way. Heck it's their system I guess they can use it however they see fit. Joe
Old 03-30-2011, 11:26 AM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,940 Times in 584 Posts
Default Re: Ahfs
It works the other way also. they hit a class for a fast run but dont nessesarily tear the car down to check to see if it is 100% legal on the run. They just assume it is legal then put the penalty on the combo. I am speaking about the more tried and tested combos not the new "soft" combos as they are called.
Mike Pearson 2485 SS
Old 03-30-2011, 01:18 PM   #8
Toby Lang
Liked 2 Times in 1 Post
Default Re: Ahfs
I guess the moral of this story is:
If you do the time, you pay the HP. Or:
If you're not sure what it will run, lift at 1000 feet. Or:
If you're not sure what the vehicle is supposed to weigh, ask somebody that does know.
I don't think this is that much different than what happened to Fred Hensen. You go quick enough on a losing run, you're gonna get HP or a flag.
Also, just an FYI, the truck got 14 HP not 18.
-Toby
Old 03-30-2011, 02:43 PM   #9
Ed Wright
Ed Wright's Avatar
Default Re: Ahfs
Sounds about right to me.
Ed Wright 4156 SS/JA
Old 03-30-2011, 02:59 PM   #10
art leong
Default Re: Ahfs
-Toby
Toby the car should not get hit if it is illegal.
How would you like it if somebody put together a combo just like yours. But bogus as can be. Goes out and whacks your hp 6 or 7 percent. Then never runs it again, and flagrantly admits they were bogus?
I wish everyone that got an instant hit was torn down. Thats the way it should be. But if a car is found wrong there should be no hit.
If they don't change it. This is just a vindictive hit, just like I have gotten before.
Art Leong 2095 SS
