Old 04-04-2011, 06:59 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question Gear split
How much ratio split between 1st & 2nd gear is the best?
Or should I say will be quicker?
MEXJOE is offline   Reply With Quote
Old 04-04-2011, 07:56 PM   #2
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Default Re: Gear split
I will ask 1st, what transmission? Snow gone up there yet? Dyno
Old 04-05-2011, 01:30 AM   #3
GTX JOHN
There are a bucket of variables and options ( At least on our Pro Trans ). Can you share some information on your combination.
Old 04-05-2011, 10:14 AM   #4
MEXJOE
MEXJOE's Avatar
200 metric
325 hp 396 Camaro e/sa
How much starting line ratio will be to much?
Old 04-05-2011, 11:59 AM   #5
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Glen, depends on the cam lobe centre, duration, shift point. With my combo if I hold it in first gear to long it will lose a tenth. John gsa 612
Old 04-05-2011, 12:58 PM   #6
ron mattson
Liked 68 Times in 31 Posts
I would think the wider your powerband between peak tq and hp the more split
you could tolerate, with that being said its still some trial and error as some cars fall
back more on the shift than others. converter, rear gears and weight all come into
play but i think your big block may tolerate more split than a low tq small block.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 04-05-2011, 01:28 PM   #7
GTX JOHN
We currently have two E/SA cars.....71 Dart 340/314 and
73 Plymouth 440/345. Both have very aggressive cams in duration @ .050 (265+) and very close lobe center (106). I do not know what is normal because
we march to beat of our own drum around here.
As different as they are they both like 2.75 low and being short shifted
out of low ( 400 - 500 below 2 - 3 shift. Hopes this helps.
