Old 04-07-2011, 08:46 AM   #11
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Re: Wheelie bars
i have contacted both parties suggested below, thank you for your replies. yes the Calvert wheelie bar rides on the trunk floor and they do suggest a 3/16 plate be installed to the bottom on the trunk so the force of the wheel that touches it does not dent it. i have seen photos and it looks good, when the wheel hits the ground it should put more force on the driving tires based on its design. i also talked to a guy at Ken Keir's shop and his bars are equally impressive and simple to install for sure. Both seem to have a good following other than the A/stick cars. Kier's is stiffening up his bar for these cars and Calvert's have been designed with these cars in mind.
Ian
Ian Hill is offline   Reply With Quote
Old 04-08-2011, 10:15 AM   #12
peter kivett
Ken Keir's web page:
www.kenkeirracecars.com
go to products and take a look at his wheelie bars.
pete kivett
peter kivett is offline   Reply With Quote
Old 04-08-2011, 10:53 AM   #13
Rob Petrie E395
Liked 216 Times in 77 Posts
Does anybody know if that single wheelie bar that ken keir makes will work on a 93-2002 4th gen camaro/firebird. I am wondering if the panhard bar will get in the way.
Old 04-08-2011, 01:43 PM   #14
Rusty Davenport
Liked 101 Times in 27 Posts
Thumbs up Re: Wheelie bars
hey Rob....the Ken Keir bars will work on the 4th generation Firebirds and Camaros but from my own experience on a Camaro I did not anticipate the 12 bolt inspection cover relocation to allow for the aluminum "sandwich" plate that the bars mount to. In my case I had to buy the LPW ultra extra low profile cover to fit under the sway bar because the cover now sits further away from the housing. It comes with special Ken Keir length bolts to allow for the cover thickness. I ended up massaging the trunk floor pan to keep the bars from hitting, but I run mine very high just for safety 3-4 inches below the bumper. I did end up modifying the panhard bar, it was just too close to suit me. I hope this helps, but it is a very nice set up once you jump through all the hoops.
Rusty Davenport is offline   Reply With Quote
Old 04-20-2011, 06:28 PM   #15
MKopp5787
Liked 7 Times in 2 Posts
The best wheelie bar for your money is by far Ken Keirs'. It's pretty simple to set up and they work flawlessly.
MKopp5787 is offline   Reply With Quote
