Liked 4,379 Times in 502 Posts
Hey guys, my car is hooking well and doing about 3 foot wheelie but when it comes down the front tires are bouncing back up in the air. Right now I am using ladder bar set for maximum weight transfer and double adjustable front QA1 shocks. I have extension all the way down to softest setting zero and compression set pretty stiff. Which do you think I need to move? Thanks.
Liked 1,956 Times in 591 Posts
If the car is bouncing the shocks are still too loose. Tighten the compression as tight as the shocks will go. The QA1 shocks might not get tight enough to control the bounce. I have Santhuff double adjustables on the front of my car. They are expensive but they will stop the bouncing
Mike Pearson 2485 SS |
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Santhuff
Marty Rinehart Jr 1125 SS STK SG SC SST |
Liked 1,912 Times in 429 Posts
Yep, Santhuff.
And dial in only the amount of bite you need. any excess wheel stand slows you down and worsens bounce. Take extension out until it stops hooking, and then loosen it back up a couple of clicks. That will keep it from bouncing back up.
Alan Roehrich 212A G/S |
Liked 880 Times in 311 Posts
Move weight forward in the car and don't spend so much time in the air!
Adger Smith (Former SS) |
