Old 04-17-2011, 04:50 PM   #1
mannymen
Liked 13 Times in 7 Posts
Default Holroyd BBC Rocker Arms
Are these the rocker arms that the Holroyd system uses?
http://cgi.ebay.com/ebaymotors/GEN-V...Q5fAccessories
Does anyone know how much his system costs? Can you buy just the 9/16ths studs and ball adjusters?
Thanks
Manny
N/A
mannymen is offline   Reply With Quote
Old 04-17-2011, 06:19 PM   #2
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: Holroyd BBC Rocker Arms
Yes but they are modified, you just cant use them like that.
Bob Pagano A/SA
Old 04-17-2011, 08:37 PM   #3
mannymen
Does anyone have pics on what has been modified or what specifically needs to be modified? Figured if it is something that I can do then l'll save myself the money and do it myself. Not paying someone for simple mods anymore.
N/A
Old 04-17-2011, 09:31 PM   #4
james schaechter
Liked 1,437 Times in 300 Posts
Thumbs up Re: Holroyd BBC Rocker Arms
I think you should call Clark.
Once you talk to him, you will realize that it is cheaper to have him make the stuff.
He has a good set up.
James Schaechter 3163 STK
Old 04-17-2011, 10:32 PM   #5
Oh no you don't . You can't weld your own rockers, but you CAN pay someone else to do it, apparently.
Maybe there IS a West Coast rule book after all.
Old 04-17-2011, 10:33 PM   #6
Larry Stewart Sr
What Holroyd sell for bigblock it works money well spent
Larry Stewart Sr is offline   Reply With Quote
Old 04-17-2011, 11:59 PM   #7
Chad Rhodes
agreed. You can't do the mods to the rockers for what he charges.
Chad Rhodes 2113 I/SA
Old 04-18-2011, 12:07 AM   #8
Grant Eldridge
Grant Eldridge's Avatar
The rockers Clark uses are Marine, identified by a particular marking inside the rocker. He has machined a re-inforcement that fits above the pushrod seat and is welded into place. The design is a nice fit, with an oiling hole that aligns with the hole in the rocker. I doubt you could do these yourself for the money, unless you could design them and had a cnc machine capable of making the inserts and did not count your time. I just got mine back from being upgraded, Clark is great to do business with and IMO his stuff is top notch. The Stud and adjusters he makes to use with these rockers are beautiful, sure they cost $$ but for a limited specialty product worth it....they are also legal as purchased from Clark.....
my 2 cents...
Grant Eldridge
Grant Eldridge is offline   Reply With Quote
Old 04-18-2011, 05:53 AM   #9
james schaechter
Mark, there were some guys welding up the pushrod sides of their rockers and no one in tech had issues with that. The rocker had to stand a lot of heat in that process. The problem seemed to be that if the rocker got too brittle, it would break anyway.
Clark cuts out a section and welds a solid piece in place. I know he asked tech if it was ok and they said it was. I don't think that eliminates someone from doing the same on their own. It would be a difficult chore unless you had the equipment and time.
Old 04-18-2011, 06:41 AM   #10
mannymen
Is the weak link the 7/16ths stud or the rocker arm?
N/A
