Old 04-16-2011, 02:31 PM   #1
Ben Kallies
Default Intake Manifold Gaskets - 1/8" Thick, BB Chevy
Does anyone make a 1/8" thick intake manifold gasket for a stock oval port Big Block Chevrolet other than Mr. Gasket p/n 107? I searched Fel-Pro and found nothing. My problem is that Mr. Gasket p/n 107 is just a cheap composite fiber gasket and is a pain in the butt to remove when it comes time to do so. I'm looking for something that won't make a mess, and is easy to remove. Thanks.
-Ben Kallies
B/S 3869
Ben Kallies is offline   Reply With Quote
Old 04-16-2011, 04:12 PM   #2
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: Intake Manifold Gaskets - 1/8" Thick, BB Chevy
Ben,
I've been taking two gaskets, stack & glue them together. Gaskets I'm using measure .058 so that puts me up around .115-.117. Bought a batch of them off of Ebay and they fit runners real good. Best I can remember they were like $5.00 a set.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 04-16-2011, 04:40 PM   #3
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Before nhra began checking runner cc's, we would contact the gasket to the cyl. head, then put a thin coat of lubriplate on the intake side, gasket could be reused a few times. I suppose you can put it on both sides without it sticking to either surface when pulling the intake. I don't believe anyone makes a thick gasket for a oval port. gsa612
Old 04-18-2011, 04:46 AM   #4
Ben Kallies
Thanks for the responses.
Old 04-18-2011, 07:49 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,946 Times in 587 Posts
Check with Dave Layer at Heads Up. He has gaskets custom cut for the small block heads to fit his port configuration. He might have some for the big block heads also.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 04-18-2011, 01:58 PM   #6
Todd Geisler
Liked 345 Times in 149 Posts
I had a new set here I sold at a flee market for $2.00 since I figured nobody would use them. lol
I got them from Cometic.
Todd Geisler is offline   Reply With Quote
