Old 04-24-2011, 11:43 AM   #1
Lonnie Cox
Wink Learning to launch
Hi Folks,
New to the Stock world. I have built a 76 Camaro small block with 350,350 trans 275 first,suppose to be 5000 stall TCI,Feels like 3500 to 4000. 4.56 gears.MSD with two step. what should my car leave at.Weighs 3775 J/SA.If I set my two step at 3400 when it goes on the two step do I mat the throttle then.I am a NEWBE! I hope to be at my first divisonal in May. Thank You for all your help.
Confussed
Lonnie Cox is offline   Reply With Quote
Old 04-24-2011, 02:42 PM   #2
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Learning to launch
one of the the items you mite want to invest in a play back tach or a data logger that reads engine rpm and drive shaft speed ,this will give you the data needed to work on your combo and see where your rpm flash launch ,wheel speed ,or traction loss ,the way ihave my car set up is industrial roller bearing micro switch on the back side of the brake arm with good adjustabuilty ,,two step set at 3400 holding the car at 900 psi on the brake gauge ,smoothly roll into the gas until you foot is on the floor and release the brake ,and hang on ,,if you have a play back tach you can see where your converter peaks once it comes off the two step gmonde
Old 04-24-2011, 03:06 PM   #3
Brian Fink
Liked 28 Times in 9 Posts
First of all , you will have to change that 4.56 for a 5.13 gear ; after that and all the other go fast tricks that you will pick up once you take the stocker plunge , you can play with starting line techniques
Brian Fink is offline   Reply With Quote
Old 04-24-2011, 04:17 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
As long as the valve train will handle 5.13 gears and tires are sized accordingly. Converter seems conservative also. But you'll know more with a playback tach. I learned A LOT with my Autometer.
I footbrake, so I can't help you with the 2-step.
Old 04-26-2011, 02:28 AM   #5
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Thumbs up Re: Learning to launch
Short answer is Yes.... try this.. stage 1st light...pull car up to 2000 stage 2nd light push 2-step button then mash the gas.
Old 04-27-2011, 12:24 AM   #6
Lonnie Cox
Smile Re: Learning to launch
Thank You for all your Expert advice!
Old 04-27-2011, 08:26 AM   #7
cad
cad's Avatar
Liked 93 Times in 52 Posts
You do have the 2 step button mounted on the brake pedal, right?
Old 04-27-2011, 01:12 PM   #8
Gary Parker
Liked 425 Times in 56 Posts
If you would like my help, let me know.... I have this combo and it does not run to bad.. Gary
Gary Parker 1617 STK
Gary Parker is online now   Reply With Quote
Old 04-27-2011, 01:45 PM   #9
Robert Simpson
Liked 20 Times in 12 Posts
[ I have this combo and it does not run to bad.. Gary[/QUOTE]
WOW that is a understatement!! This man has a bad hot rod!! Listen to him.
Robert Simpson is offline   Reply With Quote
Old 04-27-2011, 02:46 PM   #10
Ron Middleton
Liked 12 Times in 4 Posts
Gary's combo is really fast. Mine won't be anywhere near that fast anytime soon. Lisyten to Gary he knows what it takes on that combo.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
