Old 04-30-2011, 10:19 PM   #1
Jason Robertson
Jason Robertson's Avatar
Default methanol or fuel?
I always assumed most of you guys ran methanol in your s/c diggers. while i was at the track today i noticed and smelled that almost all the s/c cars were running the oxygenated race fuel. i was planning on running methanol but now thinking otherwise. methanol makes more torque, cools well, less responsive to da changes, yet no one was running it really. is it a methanol engine maintenence issue? please clue me in, sorry for the newb question.
Jason Robertson is offline   Reply With Quote
Old 05-01-2011, 12:00 AM   #2
Chris Williams
Chris Williams's Avatar
Default Re: methanol or fuel?
FWIW, I don't know anyone who runs on methanol.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 05-01-2011, 12:14 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Alcohol is for drinking!
Only a handfull of SG cars in D1 run methanol, mabe a few more in SC.
Big inch .90 type motors dont seem to benefit as much from alcohol as do smaller motors, unless you run injection.
A few racers are running Q16,but most are still running well with conventional racing gas.
Last years top 4 in D1 SG, #1 reg race gas, # 2 oxygenate fuel,#3 methanol ,#4 reg race gas.
Old 05-01-2011, 10:55 AM   #4
THE LEGEND
I run Alky. $130 for 55 gallons. Dragster uses 1.5 gallons 1/4 mile almost a gallon in the 1/8th. Camaro uses little over a half in the 1/4 and a little under a half in the 1/8th.
I change the oil at around 100 passes.
Don't be scared of alky.
A few suggestions would be.
Call George Rupert and buy the entire setup including the Belt drive pump.
Call Biondo and order a T-stop. I use the plate on both cars.
Chip Johnson
THE LEGEND is offline   Reply With Quote
Old 05-01-2011, 07:34 PM   #5
Bill Baer
[QUOTE=THE LEGEND;256071]I run Alky. $130 for 55 gallons. Dragster uses 1.5 gallons 1/4 mile almost a gallon in the 1/8th. Camaro uses little over a half in the 1/4 and a little under a half in the 1/8th.
I too run alky like the Legend said it's cheaper and more consistent I run a Rons fuel injection (A terminator) with a highspeed lean out.I also run a top oil with grape scent since it smells kinda nasty. I have a gas primer system, block and oil heaters to help with cold starts and quicker warm ups. I also run a vacuum pump.
Tips: Keep the fuel tank full so the pump stays submerged, it doesn't color the plugs so trust the ET/MPH, if you go the F.I route you need to use an inline stop. with the F.I.It's a little harder to start than a carb but the trottle response is instantaneous.
Old 05-02-2011, 02:28 PM   #6
JJ3159
JJ3159's Avatar
i run allky never had a maintence issue ,like the way it runs ,legend said rupert (very good) i also run a quick fuel alcohol carb
jj h/r 1399 s/r 1399 s/g 1399
JJ3159 is offline   Reply With Quote
Old 05-03-2011, 12:47 AM   #7
Jason Robertson
im looking at running a dart pro 1 345 cc 496 bbc(not too big by todays standards) should make 800ish on fuel. i may just go with fuel since the system is already set up for it. the pump is a magnafuel 275 and is suppose to be alcohol compatable. everyone i talked with that ran methanol was running a belt driven pump with a bleed off valve. may just play the cards im dealt with as ive heard that you can run into over rich issues at idle with an electric pump.
Old 05-03-2011, 01:49 PM   #8
Tweaker
Tweaker's Avatar
almost everyone runs methanol at my track in FL.
I'm running it in my dragster too!
IHRA #2X41
http://khracing.projectrhyme.com
Tweaker is offline   Reply With Quote
Old 05-03-2011, 04:12 PM   #9
Barney B
Barney B's Avatar
I just swith this year from alky to gas. I think that gas is more predictable throttle stop racing but that is JMO.
BB
Barney B is offline   Reply With Quote
Old 05-03-2011, 06:06 PM   #10
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I've run gas carbs including a DaVinci and a Stinnett and had one carb converted to alcohol by APD. I've also run Ron's alcohol Terminator injection......I prefer alcohol over gas and have no trouble running it. I also have no trouble t-stopping the injection and had very good success running that for a year or two. One win and one semis at Lucas races in less than a year and not racing nearly as much as many.
There is a learning curve with alcohol but it's not hard usually.
My present car was run on gas and alcohol with a carb and the same pump and regulator......Aeromotive A-2000 and a big 2 port MagnaFuel regulator dead headed. Was not deadly as it should have been but still pretty good. A belt pump with the alcohol carb is the preferred setup along with a return style regulator....
If I had a big motor I'd probably run a carb and still prefer alcohol for the cooler running in the summer. Would definately go to the belt pump with a big cube engine...
In cooler (50 or under) or damp condtions alcohol can throw you a curve....in hot weather it's the best and the hotter it is out the better....
I am running a 509 and am back to a Ron's Terminator. I am planning on doing a little t-stop racing but primarily bracket racing locally....I'll take my lumps in S/C probably but if I hit a setup right maybe I can rack up some W's......Alcohol.....runs cool....repeats very well and injection has throttle response way better than any carb.....
I took delivery of 4 drums of alcohol today.....
Rich Biebel
S/C 1479
Stock 147R
