I always assumed most of you guys ran methanol in your s/c diggers. while i was at the track today i noticed and smelled that almost all the s/c cars were running the oxygenated race fuel. i was planning on running methanol but now thinking otherwise. methanol makes more torque, cools well, less responsive to da changes, yet no one was running it really. is it a methanol engine maintenence issue? please clue me in, sorry for the newb question.
FWIW, I don't know anyone who runs on methanol.
Chris Williams 6304 SC, TD, ET |
Liked 882 Times in 236 Posts
Alcohol is for drinking!
Only a handfull of SG cars in D1 run methanol, mabe a few more in SC. Big inch .90 type motors dont seem to benefit as much from alcohol as do smaller motors, unless you run injection. A few racers are running Q16,but most are still running well with conventional racing gas. Last years top 4 in D1 SG, #1 reg race gas, # 2 oxygenate fuel,#3 methanol ,#4 reg race gas.
I run Alky. $130 for 55 gallons. Dragster uses 1.5 gallons 1/4 mile almost a gallon in the 1/8th. Camaro uses little over a half in the 1/4 and a little under a half in the 1/8th.
I change the oil at around 100 passes. Don't be scared of alky. A few suggestions would be. Call George Rupert and buy the entire setup including the Belt drive pump. Call Biondo and order a T-stop. I use the plate on both cars. Chip Johnson |
[QUOTE=THE LEGEND;256071]I run Alky. $130 for 55 gallons. Dragster uses 1.5 gallons 1/4 mile almost a gallon in the 1/8th. Camaro uses little over a half in the 1/4 and a little under a half in the 1/8th.
I change the oil at around 100 passes.Don't be scared of alky. I too run alky like the Legend said it's cheaper and more consistent I run a Rons fuel injection (A terminator) with a highspeed lean out.I also run a top oil with grape scent since it smells kinda nasty. I have a gas primer system, block and oil heaters to help with cold starts and quicker warm ups. I also run a vacuum pump. Tips: Keep the fuel tank full so the pump stays submerged, it doesn't color the plugs so trust the ET/MPH, if you go the F.I route you need to use an inline stop. with the F.I.It's a little harder to start than a carb but the trottle response is instantaneous.
Bill Baer 3391 SC, 339B SC, QR Last edited by Bill Baer; 05-01-2011 at 07:39 PM. |
i run allky never had a maintence issue ,like the way it runs ,legend said rupert (very good) i also run a quick fuel alcohol carb
jj h/r 1399 s/r 1399 ![]() |
im looking at running a dart pro 1 345 cc 496 bbc(not too big by todays standards) should make 800ish on fuel. i may just go with fuel since the system is already set up for it. the pump is a magnafuel 275 and is suppose to be alcohol compatable. everyone i talked with that ran methanol was running a belt driven pump with a bleed off valve. may just play the cards im dealt with as ive heard that you can run into over rich issues at idle with an electric pump.
almost everyone runs methanol at my track in FL.
I'm running it in my dragster too! |
I just swith this year from alky to gas. I think that gas is more predictable throttle stop racing but that is JMO.
BB |
Liked 544 Times in 213 Posts
I've run gas carbs including a DaVinci and a Stinnett and had one carb converted to alcohol by APD. I've also run Ron's alcohol Terminator injection......I prefer alcohol over gas and have no trouble running it. I also have no trouble t-stopping the injection and had very good success running that for a year or two. One win and one semis at Lucas races in less than a year and not racing nearly as much as many.
There is a learning curve with alcohol but it's not hard usually. My present car was run on gas and alcohol with a carb and the same pump and regulator......Aeromotive A-2000 and a big 2 port MagnaFuel regulator dead headed. Was not deadly as it should have been but still pretty good. A belt pump with the alcohol carb is the preferred setup along with a return style regulator.... If I had a big motor I'd probably run a carb and still prefer alcohol for the cooler running in the summer. Would definately go to the belt pump with a big cube engine... In cooler (50 or under) or damp condtions alcohol can throw you a curve....in hot weather it's the best and the hotter it is out the better.... I am running a 509 and am back to a Ron's Terminator. I am planning on doing a little t-stop racing but primarily bracket racing locally....I'll take my lumps in S/C probably but if I hit a setup right maybe I can rack up some W's......Alcohol.....runs cool....repeats very well and injection has throttle response way better than any carb..... I took delivery of 4 drums of alcohol today.....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 05-03-2011 at 06:13 PM. |
