Old 05-16-2011, 11:03 PM   #11
Terry Waldron
Question Re: Minimum and maximum weight for Stk and S/S
This weight thing is confusing to me, All I want to know is I run k/ stock with a 283 and i was suppose to weigh 3147 so am i legal or not, i usually weigh 30 to 50 lbs over that.
Terry Waldron 5619 K/S
Terry Waldron is offline   Reply With Quote
Old 05-16-2011, 11:08 PM   #12
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Minimum and maximum weight for Stk and S/S
In a word.... Yes! You are fine. 30 to 50 lbs . is smart & safe. Jim
Old 05-16-2011, 11:08 PM   #13
james schaechter
Liked 1,436 Times in 299 Posts
Default Re: Minimum and maximum weight for Stk and S/S
Terry, you are fine with that. If you show up at L weight when you claim K, you would have an issue. ( or within 5 lbs of L weight).
Don't change a thing. You coming to Earlville Memorial Day weekend for the Heartland 2 day race?
James Schaechter 3163 STK
Old 05-16-2011, 11:15 PM   #14
Terry Waldron
Wink Re: Minimum and maximum weight for Stk and S/S
Jim I plan on being there, cant make both days but be there for 1 day. Got my truck straighted out. 600 dollars later.
Old 05-16-2011, 11:20 PM   #15
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
Originally Posted by Pvt Parts View Post
Travis,
So are you going to DQ someone for weighing 3 pounds under the maximum weight as it's defined in the rule book?? “All cars will be permitted to run on the class minimum weight, but may be no heavier than the minimum for the next heavier class.” If that's the rule it doesn't say anything about 5 pounds under the minimum.
The reason 5 pounds is used is because the scales read in 5 pound increments, not 3 pound increments. The maximum weight limit works just like the minimum weight limit. The rule has always been if you are too light it is a DQ. Now with the new rule if you are too heavy it is also a DQ.
Travis Miller
(Disclaimer: Opinions expressed by me on this forum are exactly that, my opinions.)
Travis Miller is offline   Reply With Quote
Old 05-16-2011, 11:59 PM   #16
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Travis, glad to hear the news. I was beginning to think that every ruling was going to favor the factory cars.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 05-17-2011, 02:14 AM   #17
Toby Lang
Liked 2 Times in 1 Post
Travis Miller
Well, if my minimum for the next heavier class is 3500 pounds and I get on the scale and I weigh 3500, I am not heavier than the minimum for the next heavier class, correct?
You either need to change the rule to say you must weigh less than the next heavier class or allow people to weigh right on the minimum of the next heavier class.
-Toby
Old 05-17-2011, 07:33 AM   #18
Pete Beau
Pete Beau's Avatar
Liked 31 Times in 12 Posts
Travis, what is NHRA's calibration policy for the scales?
Pete Beau is offline   Reply With Quote
Old 05-17-2011, 07:50 AM   #19
dw3113
I agree with Toby. They either need to rewrite the rule or let us use the next class minimum weight for the maximum. Just my opinion. Dave Walther
dw3113 is offline   Reply With Quote
Old 05-17-2011, 08:30 AM   #20
Travis Miller
Scales are calibrated before a big meet.
The scales are usually open to anyone who wants to weigh their car. A lot of racers come down before their first run and weigh their cars. SOME DO NOT.
As with any new rule, it takes some getting use to. Those who move up a class need to weigh their cars before they run to be sure they fit between the min and max.
Travis Miller
