Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 05-25-2007, 12:31 AM   #1
sst4530
Default 9 1/2" Ford ring gear
Has anyone upgraded from a 9" to the 9 1/2" ring gear, If so did it fit in the standard rear end housing without clearance issues. Found a nice complete MW low friction unit, just not sure if it will work without housing modification.
Thanks
sst4530 is offline   Reply With Quote
Old 05-25-2007, 08:39 PM   #2
don R
Default
Lincoln made a 9 1/2" ring gear it would fit a ford housing with a notch for clearance on the mounting flange for the third member. Hope that helps.
don R is offline   Reply With Quote
Old 05-26-2007, 12:10 PM   #3
sst4530
Default
That helps a little, there's still a few other things to consider like the bearing caps hitting the back of the housing. [:-happy-:]
Old 06-26-2007, 05:12 PM   #4
M S Watchdog
Default 9 1/2 Ford
Not true it is 9 3/8 not the same, no nodular cases were ever made. the caps will break and the tail bearing retainer in the case will also crack. Every thing in the pig is just a little bigger the ring gear bolt circle is bigger. The 9 1/2 is different contack MW or Strange to see if if it will fit in your housing.
M S Watchdog is offline   Reply With Quote
