Old 06-06-2011, 10:29 AM   #11
lugnut
Wink Re: Stocker to superstocker
any new cj ford or DP will be just fine tighten them lugs
lugnut is offline   Reply With Quote
Old 06-06-2011, 11:56 AM   #12
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs up Re: Stocker to superstocker
Originally Posted by Roger K Fain View Post
'69 AMX 290 cu in 225 HP; ran it in M/S on 13.15 index, went 12.15, won two events.
Changed cam to .700 lift roller, massaged heads, Edelbrock "Torker" intake, "Quikfuel" 3310 Holley, 10.5" M/T's; run SS/M on 11.90 index, goes 10.60s in good air, won one event, so far. Almost always slowest car in eliminator, we leave first with very good driver.
And its a really cool car to. Love those AMX's. Dont ever cut those wheel tubs.
Old 06-06-2011, 12:03 PM   #13
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Originally Posted by Mike Savelle View Post
Kevin My 95 Trans Am can run both stock and Superstock the way it sits and is under both indexes.. The price is right . Mike
LOL why don't you rent me the car and my daughter can drive.Hmmmm we might have something here
Kevin
Old 06-06-2011, 12:06 PM   #14
SSGN
SSGN's Avatar
Originally Posted by Alan Warman View Post
My vote would be the GM G-Body's. You have the Malibu's the Grand National and the Olds Cutlass. They are cheap and have ton's of bolt on parts that work.
What classes will the G bodies fit.I have a couple Grand Nationals and they don" t do well in either class but sure are a nice street car.Thanks
Kevin
Old 06-06-2011, 02:05 PM   #15
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Talking Re: Stocker to superstocker
Roger,stop giving our secrets away.:<):<)
Former NHRA #1945
Former IHRA #1945
T/SA
Old 06-07-2011, 04:06 AM   #16
Jeff Lee
Jeff Lee's Avatar
Default Re: Stocker to superstocker
'68-'70 AMC AMX 2-seat 97" wheelbase. Will run fast in Stock or Super Stock on 9" slicks with Calvert rear springs and bars. I went 10.50's in D/S with a 390 and loaded a "fair" SS 390 and a steeper rear gear. Went 10.00 in SS/H. The 290, 390 (either 1968-1969 or 1970 (different specs) and '70 360
will all under by a significant margin with the 290 as Roger mentioned probably the best to build (and cheapest).
But you probably want a belly button car...
Jeff Lee 7494 D/S '70 AMX
Old 06-07-2011, 04:53 AM   #17
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
jeff, are you aware of any "approved" 290 pistons? 2bbl or 4bbl?
i'm not....
that's why i've got one (from ED F) that's gonna get sent in (to a mfgr) one of these days, probably this fall
Old 06-08-2011, 09:25 AM   #18
Roger K Fain
Tom,
Check with Hemmy Adkins or Garrett Ghezzi (SS/MA from Joliet, IL) for NHRA piston.
Dwight Southerland played around with one on a dyno also.
Roger K Fain is offline   Reply With Quote
Old 06-08-2011, 09:49 AM   #19
Lambertcars
Hi Roger
Back in the late 70s and early 80s I ran a 69 AMX in NHRA Super Stock with a 390 engine. Not wanting to move the rear springs or alter the wheel tubs the only tire that would fit was a 9 in tire. I have thought about geting another AMX but I would not want to alter the rear of the car. What if any thing could be done to use a bigger tire with the stock length rear end and no alteration to the spring location and the wheel tubs?
Thanks Allen
Lambertcars is offline   Reply With Quote
Old 06-08-2011, 12:03 PM   #20
Jeff Lee
Jeff Lee's Avatar
Originally Posted by Lambertcars View Post
Hi Roger
Thanks Allen
The biggest you will get and still have the slick inside the quarters is a 9x30. There's no getting around having to do some serious trimming of the wheel well arch for a 30" slick. Otherwise you need a shorter slick like a 28" but that is a compromise in itself. But I was still going 1.38 60' in my car with a 9x29.5 in my '70 AMX. I had another with an 11.5x29.5 with stock framerails and coil-overs but it was tubbed. You could do it by using a tub or mini-tub.
