#31 |
Liked 16 Times in 5 Posts
do you have the black tape on the secondary metering rod slots?
#32 |
Liked 6 Times in 5 Posts
Bob, No.
#33 |
Liked 51 Times in 3 Posts
jonesracing you have a PM
#34 |
Liked 1,922 Times in 432 Posts
Got this from a friend and fellow racer, a really good racer. Check the fuel pump. There was a car with this exact problem, and what was happening was that under G's from the launch, the armature of the fuel pump would move and short out. It did not show on the fuel pressure gauge. They fought this problem all year, and a new fuel pump fixed the car for the last time trial at the last race of the season.
Alan Roehrich 212A G/S |
#35 |
Liked 101 Times in 27 Posts
This is for real......check the main wiring terminal for loose connections...check them with a wrench---not your hand......when I let go of the tranny brake the connection would momentarily lose connection then reconnect when it hit the ground off the wheelstand.......do not underestimate this happening, do not trust checking with your hand I say again....I felt stupid when I started replacing parts and found out a nut needed WRENCH TIGHTNESS.
#36 | |
Ed Wright 4156 SS/JA |
#37 |
If the rain stays away we are going to try things out tonight!!
#38 |
First thing you should probably do is see if a fellow racer with a similiar combo will let you borrow his carb. for one pass so that you can make sure that is what is really causing the problem before you try chasing down lose wires or any other number of things that could be causing this.Good luck ,you'll find it.
#39 |
Well after 3 weeks of Bad Luck we went to the track and found the issue. Thanks for all your guys help. It turn out to be the button!!!
#40 |
Liked 20 Times in 14 Posts
what button?
