Old 06-21-2011, 04:12 PM   #1
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
Default Can a slick be patched or plugged?
Has anyone had any good or bad luck trying to patch or plug a slick? I have a screw in one of my tires and it only has one pass on it.
Thank you,
Larry
Larry Curtis is offline   Reply With Quote
Old 06-21-2011, 04:36 PM   #2
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Default Re: Can a slick be patched or plugged?
Thank you,
Larry
I did it with one of my hoosiers, but it was a radial and then only as an emergency for my dakota..Never had to use it...But it did hold air for 2 plus years....I didn't bother patching the hole in the dragpak's hoosier after 12 runs.....as it fell into the catagory of do I really want to role the dice on it not working out with that much HP and $....
Yours is a stick car correct?
Eric
Eric Merryfield 1883 STK
Old 06-21-2011, 04:37 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Both are done all the time and many racers including myself carry and have used a plug kit at the track and in the lanes.
Old 06-21-2011, 04:38 PM   #4
Larry Curtis
Yes it is a stick car and has bias plies on it.
Old 06-21-2011, 05:37 PM   #5
Joe DeMarzo
Liked 121 Times in 11 Posts
After the first bun out the plug is melted in, no problem getting 75 runs on a plug.
Joe DeMarzo 1317 STK
Old 06-21-2011, 06:20 PM   #6
Rory McNeil
I have sucsessfully used "patch plugs" on bias ply slicks. These are a combination of a round patch with a plug in the center.
NHRA 6390 STK
M/S 85 Mustang
Old 06-21-2011, 07:21 PM   #7
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: Can a slick be patched or plugged?
Larry, I feel your pain. I have several sets of Hoosier and Mickey Thompson slicks I could send you. My partner wants to keep fresh tires on the car. Imagine that. Do not patch that slick. You have a lot invested in your car to take a chance like that. Think about it?
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 06-21-2011, 07:29 PM   #8
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
I had a flat last year at Topeka on a new radial that had 1 pass on it. Put a patch on the inside and it has worked fine. Dyno
Old 06-21-2011, 08:15 PM   #9
John Dinkel
Liked 265 Times in 69 Posts
I had to pug a brand new Hoosier Radial. First time out it went flat. Put a radial plug and was very scared it would come out. Watched it carefully for several races with no problem. Wore the set out.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 06-21-2011, 08:34 PM   #10
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Can a slick be patched or plugged?
I used a tube to repair a radial slick. Put one in the other tire even though it didnt need one so they would be the same. The car was already slow so it didnt matter.....LOL. Wore them out after many runs and they never went flat again.
