Old 06-22-2011, 11:35 PM   #11
Liked 1,855 Times in 420 Posts
Default Re: 9 on 10
We screw our slicks to the rim. We found out with the AA/SA car that the slicks moved on the rim if we didn't.
Old 06-23-2011, 07:28 AM   #12
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: 9 on 10
Originally Posted by Ron Gusack View Post
Why is it bad to run screws?
it's not a question of good or bad, it's just that you don't need them if you're not running tubes so why ruin a nice pair of wheels?
I've run a best of 1.17 60 foot on 32 x 13.5 Hoosier Radial slicks with my current 3130 lb. ride and a best of 1.28 60 foot on 30 x 10.5 Hooiser Radial slicks with my former 3880 lb. ride and the tires have never been screwed to the rim and I make north of 200 passes a season.
I also haven't swapped my tires side to side in over 10 years and my 60 foots are deadly consistent varying thousanths on any given day from pass to pass.
That said, walk the stock/super stock pits at any divisional and national event and you'll see the vast majority of those going rounds, winning races and championships do not have their tires screwed to the rim including the the winningest car in NHRA history.
Have your slicks mounted dry, meaning no soap/mounting lubricant. Yes they will move on the rim for a few passes which doesn't effect consistency nor is it anything to be oncerned about.
Old 06-23-2011, 11:30 AM   #13
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: 9 on 10
Ed, if these were new wheels, I'd take your advice and try to run them screwless. These are old Center Lines that have holes already drilled in them, so I'll screw them.
Ron Gusack is offline   Reply With Quote
Old 06-23-2011, 04:44 PM   #14
Run to Rund
Liked 54 Times in 27 Posts
Default Re: 9 on 10
"sand" blast the bead areas with 80 grit aluminum oxide such as Harbor Freight sells cheaply. If you have trouble with the wheels squirming on the brake drums or hubs, blast those areas too.
Old 06-23-2011, 05:11 PM   #15
Rod Greene
Liked 242 Times in 81 Posts
Default Re: 9 on 10
When I was going to try the TOYO tires the rep I talked to recommended no bigger than a 9" rim. He said the sidewall was made to work on a narrower rim. When I raced my car I never had rim screws and it was a stick shift 3205lbs 7000rpm launch 3.19 first gear 5.57 rear. It would move the tire an inch or so every 6 passes then I would swap sides.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 06-23-2011, 07:50 PM   #16
Ron Gusack
Ron Gusack's Avatar
Default Re: 9 on 10
I wish I knew that before I bought these 10 inch rims. These weren't easy to find.
Old 06-24-2011, 01:25 PM   #17
Run to Rund
Default Re: 9 on 10
I talked to a Toyo distributor when they had the 2 for 1 sale and he cautioned me that a lot of the tires were 2-4 years old.
Old 06-24-2011, 11:52 PM   #18
Ron Gusack
Ron Gusack's Avatar
Default Re: 9 on 10
These are 07's, if you go by the last 2 digits. They didn't hook worth a damn tonight. Some of the problem is the track, but it's mostly me.
Old 06-25-2011, 06:00 AM   #19
Kevin Lang
Thumbs up Re: 9 on 10
Ron, you could also try a compound called bead sealer that tire shops use. It is a tar like compound that is sticky and works well to keep tires from moving at all. it is messy to put on but easy clean-up once it dries. you just have to resist the urge to wipe it up while it is still wet. comes as brush-in-can like anti-seize compound.
Kevin Lang is offline   Reply With Quote
Old 06-25-2011, 08:56 AM   #20
Ed Wright
Ed Wright's Avatar
Default Re: 9 on 10
Hoosier also says no wider that 10" wheels for my 10.5" radials, but 11.5" wheels made it a new car. I have mentioned that to two different Hoosier reps, both seemed very surprised. Absoluty no more "radial wobble". It's quicker, faster and likes more air in the tires.
Ed Wright 4156 SS/JA
