Old 06-23-2011, 10:40 AM   #11
Casey Miles
Liked 508 Times in 92 Posts
Default Re: 4 Speeds
On the super t-10's the first gear doesn't sit correctly on the cluster, it only meshes about 3/4 of the first gear, you may want to have the gears machined to fit on the cluster better.
Casey Miles
248H Stock?
Old 06-23-2011, 11:06 AM   #12
larrylomascolo
Liked 66 Times in 29 Posts
A muncie with all Liberty gears would be an improvement over stock
Old 06-23-2011, 11:36 AM   #13
Jeff Colvert
Jeff Colvert's Avatar
Liked 3 Times in 2 Posts
Wink Re: 4 Speeds
I could go back and run a stock trany (IF) we went back to stock un-ported heads, stock block, rods and crank other wise there aren't enough stock trans parts left to run one of these cars. Back before Jerico came out I would have fresh trany in car, one in the trailer and enough parts to build one at the track and did that on a few ocasions. On second thought forget it I wouldn't go back for any reason I broke two Jericos last year so an auto don't sound all that bad. Just boring.
Jeff Colvert SS/G,F,GT/B 4456
Jeff Colvert is offline   Reply With Quote
Old 06-23-2011, 06:02 PM   #14
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
hey Jeff, have you bumped your heads..did you just say auto?
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 06-24-2011, 12:02 PM   #15
Jeff Colvert
Smile Re: 4 Speeds
Ok Stephen so I had a moment there. I'm over it . Lets jam some gears. Nothin like pullin that Cobra Jet in high and letten her eat.
Hope Dad is doing well tell him hi.
Old 06-24-2011, 02:08 PM   #16
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Casey,
I've cut low gear to line up with cluster,I have found a 9310 low gear,Thank's Scotty D for the info.
Larry,
All Liberty has for Muncie or T-10 is a few parts and pieces in storage they have'nt had gear sets for them for a while as far as I know,they do still pro shift them but that is about it on T 10 or muncie.
Jeff,
You had me concerned there for a minute,I like watching you run. I owned 2 autos my first and last,without a stick it's no fun for me. Turn it loose on high side chip and try to rip shifter off every gear is best stress relief I know.
Mike Taylor 3601
Old 06-24-2011, 02:48 PM   #17
Casey Miles
Mike Taylor: There's a Liberty gear set for a Muncie on Ebay now. You are better off with a Super T-10 Liberty though. Once you have straightened out first gear, it should be OK. There is a place called S&K Speed shop on Long Island, the guy there is a guru on Super t-10s. He can make a fully sync trans. shift like butter. Use a soft clutch and it will live a long time.
Casey Miles
248H Stock?
Old 06-24-2011, 02:50 PM   #18
Jeff Colvert
Originally Posted by Mike Taylor 3601 View Post
Casey,
Larry,
Jeff,
Mike Taylor 3601
Yea Mike the stick does peg the ole Fun-O-Meter but its dishearting when your trans mfg. telles you there really nothing they can do for you, your car is too heavy and makes too much HP. Thats something I thought you could never have too much of.
Old 06-24-2011, 03:06 PM   #19
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
Originally Posted by treessavoy View Post
Question: Would you guys still race a stick if it had to be the one that the car was originally equiped with ? B&W, mopar, toploader etc.
JimR
I would not have put a stick in my car if I had to use an A-833 or t-56.
Larry Curtis is offline   Reply With Quote
Old 06-26-2011, 01:35 PM   #20
Hemi Moose
Liked 12 Times in 12 Posts
Really, I thought the 18 spline hemi trans A833 was a pretty tough tranny back in the day, but I'm sure there's much better trans racers use for a replacement today.
