Old 06-21-2011, 03:42 PM   #1
Joe DeMarzo
Liked 113 Times in 9 Posts
Question gear shift and the dyno
How would you use the dyno sheets to help determine what to shift 1st to 2nd and then 2nd to 3rd in a small block stocker? We use the dyno sheets as a guide for the converter stall, is there a formula or guide for torque & HP in relation to shift points? Then it will be time to test that theory. How does everyone determine before testing what to shift at their cars at?
Joe DeMarzo 1317 STK
Old 06-21-2011, 04:26 PM   #2
ron mattson
Liked 67 Times in 30 Posts
Default Re: gear shift and the dyno
this is a very good question, i use peak tq to figure stall speed and peak hp for shifts
and then look at the playback to see where motor falls back to after each shift and
adjust accordingly. P.S. Joe you have p.m.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 06-21-2011, 04:55 PM   #3
Joe DeMarzo
Ron, I have PMed you back.
Old 06-21-2011, 11:06 PM   #4
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Dyno with shift simulator.. This is cool!
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 06-22-2011, 07:40 PM   #5
Owen S Quirion
Joe,
The way I do it is to determine the RPM drop going from 1-2. Then look at your Torque curve to find the peak and also see how flat the curve is around the peak. I take the net rpm difference and overlay that around the torque peak to try to take as much advantage of the flattest part of the torque curve when the engine is recovering from the shift. For the 2-3 I would run the car out closer to the HP peak using the same RPM Drop philosophy.
BF/S 1985 Grand Am 3.0 V6
Owen S Quirion is offline   Reply With Quote
Old 06-23-2011, 10:48 AM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Superflow says about 10% above peak, on glide that work pretty good,but 3 spd. or stick is a little much for low gear, what I always have found is usually shift low as soon as can without bogging then second close to peak to about 10% above peak hp rpm.
Like everything else depends on lots of factors,closer ratios are together less you'll need
to stretch out that gear,most cases the sooner you can get in high gear the quicker it will be.
Mike Taylor 3601
Old 06-23-2011, 05:47 PM   #7
Vic Santos
Vic Santos's Avatar
Liked 14 Times in 2 Posts
Joe, here is my theory. First maximize the HP put to the track in high gear by gearing the car to go through the eyes at approx. 10% above the dyno peak HP rpm. Next choose a convertor that flashes 150-250 rpm above the dyno peak torque rpm. The 1-2 shift is done at the track by testing. Shifting early (below the peak HP rpm) takes you back into torque multiplication in the convertor while in the high torque rpm's. You are trading HP for more torque at the wheels early in the run. This usually helps ET. The 2-3 shift should be such that the engine falls to approx. 10% below dyno peak HP rpm. The result is that high gear (the one you spend the most time in) goes from -10% to +10% of dyno peak HP rpm.
Testing is the hard part. You need good shift points and good data (air shifter and data logger) as well as good traction and a good valve train.
Good luck, Vic
Vic Santos is offline   Reply With Quote
Old 06-23-2011, 09:43 PM   #8
Joe DeMarzo
Vic you have a pm.
Old 10-05-2018, 07:59 AM   #9
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Who makes this for engine dyno ?
Glenn Briglio is online now   Reply With Quote
Old 10-05-2018, 11:30 PM   #10
Kevin Musial
Liked 10 Times in 3 Posts
That looks to be a Depac dyno systems controller.
https://www.depac.com/loadcontrol.htm
Kevin Musial is offline   Reply With Quote
