Old 06-23-2011, 01:48 AM   #1
Lonnie Cox
Smile Torque converter recomendation need help
I have a 3620 lb 76 Camaro/350 030 over,I/SA 5:13 gears.9x30in tire
Cam specs
intake exhaust
.391 .411
duration
281 290
valve timing
@ .050 int 25 btdc 49
exh 64 btdc 20
with 102.0 intake center line
duratio @ .050 intake 254 exh 264
Please if you can recomend a mfg and stall
I tested my car with the 4:56 and tci 8 inc converter and only ran 13.64 @ 97 mph the car would only stall to about 3000, I have now installed 5:13 gears and I am having a shop loosen the converter.
Thank You for all your help I just want to qualify.
Lonnie Cox is offline   Reply With Quote
Old 06-23-2011, 02:54 AM   #2
Liked 5,129 Times in 1,956 Posts
Default Re: Torque converter recomendation need help
The stall needs to be well over 5000, but how you get there is important too.
PM me if you'd like a specific recommendation. Need to know where you live .
Old 06-23-2011, 09:38 AM   #3
tj310
You should get more mph with that combo, even if the convertor is too tight . Is that an up to date brand name stocker cam? ...Thanx Trevor
Old 06-23-2011, 09:53 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Call ATI and speak to Charlie Plott
Old 06-23-2011, 10:24 AM   #5
Jacob Pitt
Call Lenny at Ultimate Converter Concepts. His stuff is all I will run in my Stocker and my bracket cars. He is also a site sponsor, and a great guy to deal with.
Family Tradition Racing
Jacob Pitt is offline   Reply With Quote
Old 06-23-2011, 03:46 PM   #6
Lonnie Cox
It is a Comp Cam
Old 06-23-2011, 04:08 PM   #7
Liked 1,865 Times in 422 Posts
Originally Posted by Lonnie Cox View Post
It is a Comp Cam
Call Tim Cole or Chris Padgitt at Comp to see if it is up to date.
I'd look at a 5.38 gear. The converter should probably flash closer to 5000-5500.
Old 06-25-2011, 09:25 PM   #8
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
2nd the call to ATI.....5.13 gear is fine as long as you have a 2.75 low gear in the trans. ( a 2.91 metric would be better but..)
Old 06-26-2011, 10:19 AM   #9
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Don't confuse what stall you can reach on the brakes with flash stall. A 5000 or plus converter will only stall about 3000 on the brakes. Have a name brand converter mfg. modify the converter based on your specs. The mfg. will get it right at the start.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
