Old 06-28-2011, 02:29 PM   #41
Liked 17,170 Times in 1,559 Posts
Default Re: Class Racer.com teams with IHRA for Summit Racing Equipm
Yes, your NHRA number will be used. No need to get a IHRA number.
Old 06-28-2011, 08:10 PM   #42
butch8908
Liked 1,038 Times in 204 Posts
Butch, I do not have any numbers, but I would think at least 70 to 80 stockers and 50 to 60 super stockers. There is no other racing in the area, and with a guaranteed payout of 5000, I think we could have a very good turn out.
I was also told that There will be a first round ladder. The re-entry round will be random pairing, no heads-up runs. The second round through the finish will be back on the ladder.
Ken,
Hopefully you will be racing? There will also be the other sportsman classes, right? Field should probably be arount 300 total? Trying to justify my 8 hour drive for the saturday qualifying.
Old 06-29-2011, 04:01 PM   #43
Below is an email sent to me from Royce Miller. Below the email is all the info on pairing and ladders.
I have order a pallet of C11 that will be here for the event. If you could get the word out through the forums that would be great. Also if anyone has questions on ladders, every class (except ET) will be on a ladder from first round on except re-entry which will be random pairings. The second round ladder will be constructed from all first round winners and re-entry winners based on their original qualifying positions or higher. In other words if the number 3 qualifier would lose everyone under him would move up a position in qualifying for the second round ladder and so on down the line. Let me know if you have any other questions
Thanks, Royce
CLASSES:
> TOP SPORTSMAN: (ALL RUN; 7.60 MAX DIAL)
> TOP DRAGSTER: (ALL RUN; 7.40 MAX DIAL)
> STOCK: (ALL RUN; LADDERED; HEADS-UP RUNS ON LADDER)
> SUPER STOCK (ALL RUN; LADDERED; HEADS-UP RUNS ON LADDER)
> QUICK ROD/SUPER COMP: 8.90 INDEX; LADDERED
> SUPER ROD/SUPER GAS: 9.90 INDEX; LADDERED
> HOT ROD/SUPER STREET: 10.90 INDEX; LADDERED
CLASS ELIMINATIONS: Stock & Super Stock determined by final qualifying position
QUALIFYING:
Top Sportsman & Top Dragster - Based on Low ET
Stock & Super Stock - Based on Index
.90 Classes - Based on the IHRA “Package” Qualifying System
ET Classes - None
Juniors - None
LADDER & LANE CHOICE:
Round 1 ladder; Lane Choice to Low Dial
Re-Entry Round (Still Round 1) Random Pairing Based On Card Draw; Lane Choice to Low Dial
Re-Ladder for Round 2 through Finals based on original ladder position; Lane Choice To Low Dial
Round 1 ladder; Lane Choice Is Coin Flip or Driver Agreement
Re-Entry Round (Still Round 1) Random Pairing Based On Card Draw; No Heads-Up Runs; Lane Choice to High Card
Re-Ladder for Round 2 through Finals based on original ladder position; Lane Choice Is Coin Flip or Driver Agreement
.90 Classes
Re-Entry Round (Still Round 1) Random Pairing Based On Card Draw; Lane Choice to High Card
Agreement
ROUND 2 LADDER:
The round 2 ladder will consist of 1st round winners and re-entry winners. All competitors advancing to the second round will be put back on the round 2 ladder in as close to their original qualifying spot as possible. For example, a competitor who qualifies #1 and wins their first round will be placed back on the #1 spot of the ladder for second round. A competitor may move up in their ladder position for second round if higher qualified cars are defeated in the first round or in the re-entry round.
ET Classes & Juniors
Qualifying: All Run
Ladders: None
Bye Runs: Bye runs are determined by drawing cards - the bye run may not be declined. The first eight cars in each lane are eligible for the bye. Cards are shuffled and cut. The top card will determine which car has the bye. Left lane is represented by black cards, right lane is by red cards and the number on the card determines which car back in line receives the bye. That car will pull out of line and will receive the bye if there is an odd number of cars. Drivers can get only one bye per event unless all cars remaining have had a bye. Broke bye runs are awarded in the event that your opponent is unable to race. This occurs only after you have been paired. If it occurs prior to pairing, which is in the lanes, no solo will be awarded. Broke byes are still eligible for regular bye runs.
Any bye run car that elects to just take the tree and back off the starting line must still go to the end of the line in the staging lane they choose.
Staging Lanes & Pairings: Never block the entrance of staging with your race car, trailer or pit vehicle. Please stay with your car at all times while in the staging lanes. The staging lanes & pairing policy applies to all E.T. classes (Top E.T., Mod E.T., & Junior Dragster). Once you have selected a lane to run in and have come to a complete stop in that lane, you cannot switch lanes or move in front of or behind a racer for any reason. A bye run will be pulled every round even if there is an even number of cars, this is to prevent cat and mouse games in the lanes. Once the bye run is pulled cars will be paired side by side.
If we run out of cars in one lane, then they will be run front to back with the front car having lane choice. This pairing procedure will be used all the way up to, but not including the final. In the final, drivers will draw high card for lane choice (ace is low). You are considered a pair once your front tires enter or pass the pedestrian crosswalk in the staging lanes. Inability to run once paired constitutes a broke bye. As you pull around to the pad make sure that you remain paired. It is impossible for the tower to determine who is paired until you enter the water. In the event that you reach the waterbox and are no longer paired correctly, do not start your burnout. Grab the attention of the waterbox personnel and tell them you are not paired correctly so that the issue can be resolved. If you stage, it is a race - there will be no re-runs for wrong pairings, even if both drivers agree!
Old 06-30-2011, 04:57 PM   #44
THE LEGEND
I guess Royce just cleared up the pairings question. So now Who is coming and Who is not.
Count me in with 2 entries and RE-ENTRY money in my pocket if needed.
Chip Johnson
THE LEGEND is offline   Reply With Quote
Old 07-01-2011, 06:39 PM   #45
tim worner
Liked 126 Times in 20 Posts
Like I posted on another subject no AHFS to worry about. Let's just see how fast you can really go.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 07-05-2011, 05:48 PM   #46
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
What does this mean? No actual class eliminations but just go down the qualifying order and see which car is quickest in each class?
'65 Mustang SS/L & L/SA
Old 07-05-2011, 11:16 PM   #47
Brandon Peterson
Yes...to win class they take the top qualified car in each class...no real runoffs
Brandon Peterson is offline   Reply With Quote
Old 07-07-2011, 03:40 PM   #48
butch8908
Ken,
Is this being sanctioned by IHRA or NHRA? I'd like to take pictures from the track and I probably wouldn't be able to if NHRA is sanctioning it.
Thanks,
Butch
Old 07-07-2011, 10:01 PM   #49
Brandon Peterson
ken,
is this being sanctioned by ihra or nhra? I'd like to take pictures from the track and i probably wouldn't be able to if nhra is sanctioning it.
Thanks,
butch
ihra
Old 07-08-2011, 08:13 PM   #50
Future Stock
Does anybody have an update?
Future Stock is offline   Reply With Quote
