I'm new and need help degreeing the cam in a 305 chevy stocker the lobe separation is 106. I was told to degree it at 99 (not by the cam grinder but a fellow bracket racer) that seems like to much advance to me but like i said im new and don't know. Any help where to degree it would be greatly appreciated. Its in an 85 camaro with a q-jet carburetor. Its the 190 hp that will run in i/sa.
Liked 30 Times in 17 Posts
az,
If the cam grinder told you that would be the best place to run it, then that is what I would do. I have put one in that far advanced before on a dirt track engine. I dont claim to be anything close to a camshaft expert, but one thing I will do is listen to the cam company. If they tell me to put it in at 99, thats at least where I am going to start. I would absolutely call them and make sure there was no mistake made on the cam card. And, unless someone here is running the exact same combination, any suggestions are only speculation. Just my opinion,
Bill Koustenis |
My 305 stuff (dished and flat top) would never allow me to run the cam that far ahead but if yours will fit there......run it; you can always back it up if it doesn't like it. If you are really new at this, remember that the piston-valve clearance on these engines can be basically zero with a checking spring (intake side only). TT
#4 | |
If the guy who spec'd it had it ground with 4° advance, and you want to put it in 6° advanced based on a suggestion you will most likely not be able to tell the difference on a bracket engine. On a class engine, you may be able to tell the difference between 4° and 6° advanced by ET's and on the Dyno |
Liked 804 Times in 168 Posts
Generally speaking if it is a stick car, run it straight up to start, I have never run more than 2 degrees advanced in every 305 stocker engine of mine. (all sticks) If it is an automatic, the tendency is to run it advanced some, but the piston to valve may determine how far forward you can push it. It is trial and error on what will run best, and it may run best straight up even with an automatic. there are alot of contributing factors, and very few cam co's know for sure what will be the best for your setup
Dave Casey 1330 STK |
Liked 5,137 Times in 1,960 Posts
I'd probably split the difference and install it @ about 103, but ,as mentioned, check your clearances. You'll know if you can advance it some more,...after evaluating your 60', MPH, and traction situation with the car itself.
Where are you located?
#7 | |
Liked 165 Times in 59 Posts
no matter where you put the cam just make sure you check piston to valve clearance ,you can all ways change it back if you dont feel it's up to par ,,,,,gmonde
I would like to thank you for the help. I am going to start at 103 as Dave Casey and Mark Yacavone suggested........again thank you
