#101 | |
Liked 5,139 Times in 1,962 Posts
Back when Billy and I talked about that combo, we determined the carb was too small. The cylinder heads looked killer though. I was going to classify those tubes as emission devices ,which are removable and then see if anyone missed them. I doubt it. There are later model 232 V6s that look pretty good on paper.
#102 |
Lately ,I ' ve been looking at the 77 Pontiac 400/180 in the big cars. It's down to 260 hp, where the same motor in the Firebird is 285.
I've got a Bonneville 2 dr here that will make N/SA with no rollbar, if anyone's interested.
#103 |
Liked 60 Times in 12 Posts
Thanks to you guys with the wealth of info, that you have, this is one cool thread ! Thanks for the great reading !
2894 STK |
#104 |
Liked 783 Times in 195 Posts
Mark -
Hush on all those Pontiacs. |
#105 |
OK Mark you and talked a little about this one, 92 SC T-Bird. These things are usually sitting in somebody's yard with a blown head gasket. C4 will bolt up to the engine, 8.8 rear axle, headers..would be expensive and the car is a bit on the heavy side, I believe it would fit into R.
67 Ford Fairlane F/SA 749 |
#106 |
Liked 6 Times in 5 Posts
Gentlemen, I'm guessing the '69 Dart with 318-2V 230/230 wouldn't be nearly as good a combo as the 318-2/185??? '69 Looks like an N-O-P combo. Your thoughts ??????
#107 |
Todd - The 318 2-bbl is rated at 185 in Stock, 230 in SS in 1969. Look at the bottom of the engine column that has one asterisk (*) to see the power rating factor.
When NHRA defactored this engine back in '05, they hit every engine in every year from 1967 thru 1982. Because there are so many years this engine combination was produced, it would behoove somebody interested in racing it to research all the specs for every year and the bodies you can use. Slight advantages may be found in all those intake manifolds and carburetors. I will tell you that the cylinder head selection is basically the same for all years and that I could not find any camshaft advantages. If you already have a '69 Dart, it probably has as much potential as any other combination. You didn't say which body style you have, but a GT hardtop has a weight break of 16.01 and will make it an O-P-Q car, which would be able to get away from the more populated 15 and 16 lb classes. I also think the engine will be more capable of producing competitive torque than hp, which would favor the heavier combo. |
#108 |
Although I targeted the Camaro and Firebird combinations for the late 70s Chevy 305, one of the reasons I have been "pushing" this engine for such a long time is that it is available in so many bodies during those production years. Look at full size Chevrolets, Pontiacs, Buicks, and Oldsmobiles for applications. There are even '76-'77 Chevelles and Novas that make U/SA, if that is interesting to you. Cutlasses, LeMans and a variety on mid-sized Buicks used that engine at various times. Lots of possibilities!
#109 |
Liked 4 Times in 4 Posts
Billy or one of you guys will know this.
Is the 230 Chevy inline in the early (60-64) Chevy II a viable combo? If I remember correctly you could get this with a 4 sp as well as auto and 3sp. JimR
Jim Rountree |
#110 | |
Guest
Posts: n/a
The car classification guide doesn't specifiy auto/manual or I don't see it anywhere...oh...the engine blueprint section...got it! Will NHRA bother you if you use a five speed manual only making four shift down the track? I'd like to daily drive this car, I beleive that is a distiguised trait often overlooked but, appreciated by the distinguised... I'll post pics and video of the entire step by step if I do indeed spend less than $5000. I really would enjoy this fiscally sound project and have others buy into it aswell.. My chevelle is not going to be done sooner and for less money, that's a fact! Thanks for the thread! Last edited by Jason Fuller; 07-05-2011 at 02:48 PM. |
