Old 07-11-2011, 11:08 PM   #1
Grant Eldridge
Grant Eldridge's Avatar
Default Fuel Pressure Sensor for LM-1 Data logger
Looking for a sensor to hook up fuel pressure monitoring to my Innovate LM-1 data logger. I've been able to monitor oil pressure with a small 1/8" pipe threaded sensor that is 0-100lbs and is powered by a 5 volt supply I've built into the car, but this sensor is not sensitive enough in the 0-10 lb. range to get adequate readings for fuel pressure. Has anyone had any luck finding a source for a sensor at reasonable (low) cost that will work? There is a Racepack one available, but at $250. way over my limited budget. I lucked out with surplus sensors someone was selling online for the oil pressure, does anyone have an idea for something similar for the fuel pressure? The oil pressure one I have plugs in with a NAPA available map sensor plug, quite small in size and looks/works well. Any thoughts? Suggestions appreciated!
This thing needs to output a signal of 0 at lowest pressure to no more than 5 volts at maximum pressure, with a 5 volt power input and a ground. Probably could work ok with a bit higher range like 0-20 as long as I can map out a voltage chart per pound of pressure increase for the software to interpret in that 0-5 volt range. Thanks!
Grant Eldridge
E/SA 6650
Grant Eldridge is offline   Reply With Quote
Old 07-12-2011, 12:21 AM   #2
Darcy Clarke
Liked 529 Times in 36 Posts
Default Re: Fuel Pressure Sensor for LM-1 Data logger
I used autometer 1/8" electric sender and fed it 5 volts and used mechanical gauge to set the parameters.
Darcy Clarke
6254
AA/SA SS/JA
Darcy Clarke is offline   Reply With Quote
Old 07-12-2011, 09:27 AM   #3
MOTORSPORTS Innovations
MOTORSPORTS Innovations's Avatar
Liked 15 Times in 2 Posts
I have a great supply of 0-5 volt sensors that work on any data system. In fact, Innovate and some others buy sensors from me for their kits.
a 0-25 PSI sensor is $130
Pressure: http://www.motorsportsinnovations.com/WB_Pressure.htm
Travel: http://www.motorsportsinnovations.com/wb_Travel.htm
MOTORSPORTS Innovations is offline   Reply With Quote
Old 07-12-2011, 11:13 AM   #4
R. Thorne
Liked 101 Times in 34 Posts
Would this work? 30-2131-15g (aem performance electronics about $60). Specs are on the web site. Ron.
R. Thorne is offline   Reply With Quote
Old 07-12-2011, 05:24 PM   #5
Gauge guy
Grant,
We offer a 0-15 psi sensor, part number 2245, which is .5 volts at 0 and 4.5 volts at 15 psi. This can be purchased through anyone that sells Auto Meter.
Gauge guy is offline   Reply With Quote
Old 07-12-2011, 08:14 PM   #6
Grant Eldridge
Thanks for all the help! Looks like the AEM unit is the most cost effective and comes with a voltage/psi spec chart to enter into the software, as well as the connector pigtail all for around $60. There's even an AEM dealer near here, so should solve my problem, or they sell direct online. Much appreciated, all who replied!
Grant Eldridge
E/SA 6650
Old 07-12-2011, 10:13 PM   #7
R. Thorne
Make sure you order the 30-2131-15g and not the 30-2131-15 (absolute pressure) . Let me know if this works for you as I will be doing the same thing in a week or so. Ron.
