Old 07-22-2011, 01:04 PM   #1
3pedals
Default Cal Tracs and Instant Center????
I have a set of slide-a-links on my 67 camaro, that I have modified to have a solid rod at the bottom to be like cal tracs. I have measured and roughly calculated using the main leaf as the upper link, that the IC is at about 78" in front of the rear axle, and about 5.5" off the ground. I beleive the neutral line on my car to be at about 9.5" off the ground at the same 78" in front of the axle.
1/2 the people say the cal-tracs dont effect IC, that the front spring eye IS the IC, and the other half say that YES the cal-tracks do effect how the rear suspension reacts to the "hit" just like altering a car's IC, and pivot point adjustments DO effect change.
What do you guys think????
If the cal-tracs do effect it, then where should I try to get the Instant Center. I know that I should have some anti-squat in the IC setting, but unsure where to attempt to position it, I have to modify the pivot points to acheive this so I am looking for advice.
Please dont tell me to spend $350 bucks and buy the CAL-TRACS, I would like too, but I have already wasted $350 on the slides inks, and I dont have alot of spare cash. I know I can modify the pivot points on the bars I have, to get them to work, I just need the technical advice about IC location.
If anyone has any other leaf spring setup advice, please share it
This on a stick shift 67 camaro, 6.0l LS, stock suspension, 28x 12.5 ET street bias. Car weighs 3425 roughly with me in it and has run a best of 11.39 @ 120 w/ a crappy 1.60 60 ft. I really need to improve traction to get it to 60ft better. Slow speed video of the launch shows the rear tires turning about 8-10 revolutions before the car even moves, and the rear does not separate untill after the tires start to bite.
Barrett
3pedals is offline   Reply With Quote
Old 07-22-2011, 05:23 PM   #2
Phillip marvetz
Phillip marvetz's Avatar
Default Re: Cal Tracs and Instant Center????
Whatcha using for a clutch?
2009 V/SA Record Holder
Old 07-22-2011, 05:54 PM   #3
3pedals
11" Ram Single iron. it is at about 550lbs static right now, has no counterweight added to the CW levers.
I have tryed the static down so low to where the car wont even move when you let out the clutch, only when revs come up to about 1800, and it still BLOWS the tires away, even with launch rpms as low as 5000rpm. In fact the 60ft improved when I forgot to turn on the 2step, and left of the 7200 high side limiter lol, that was the 1.60, all others were 1.64 - and up, sometimes way up.
I am convinced the problem is in the rear suspension??????
Old 07-22-2011, 06:05 PM   #4
Phillip marvetz
Have you tried another set of slicks? I have set that just wont hook for some reason. Switched them out and picked up big time.
Old 07-22-2011, 06:18 PM   #5
3pedals
this is the second set of M/T et street bias 28x12.5's. 1rst set was an older pair, this set is NEW. EXACT results with both
Old 07-22-2011, 09:46 PM   #6
TOSTO RACING
TOSTO RACING's Avatar
Liked 652 Times in 184 Posts
Put slicks on it et streets just won't cut it. You need a stiff sidewall slick.
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 07-22-2011, 09:55 PM   #7
Phillip marvetz
Ding, Ding, Ding, We have a winner!
Stiff sidewall slicks will be much better.
Old 07-22-2011, 10:30 PM   #8
3pedals
OK , I plan to try that type tire next
Do you have any input on the original question - does the cal tracs change the effective Instant Center of a leaf spring suspension?
Old 07-23-2011, 12:23 AM   #9
Phillip marvetz
I think your putting the cart in front of the horse.
It will be pretty hard to make your car work consistently with what you have. The traction bars will help but are not the answer.
Old 07-23-2011, 02:01 AM   #10
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
I think you're overthinking the suspension. As stated, you need real slicks. Maybe take some clutch out and lower your launch RPM. Myself, and others I know struggled with Cal Tracs and adjusted them all over the place with no improvement until the rest of the setup was right. The lower pivot hole theoretically moves the I/C farther out and softens the hit. The top hole hits the tire harder. Do you have adjustable rear shocks?
Dale Posnick
Dinsdale is offline   Reply With Quote
