Old 07-24-2011, 10:57 AM   #1
Hans Olsson
Hans Olsson's Avatar
Default Adjusting valve lash with Schubeck lifters.
What is the preferred way of adjusting Schubeck hydraulic lifters?
Zero lash,preload or lash?
Our car has a Ford 351C motor.
Thanks
Hans Olsson is offline   Reply With Quote
Old 07-24-2011, 11:54 AM   #2
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Default Re: Adjusting valve lash with Schubeck lifters.
Hans, email me.... Dee9275@yahoo.com I run the 73' cleveland with the schubecks.
Thanks, Duane
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 07-24-2011, 01:24 PM   #3
Hans Olsson
You have mail.
Old 07-24-2011, 06:10 PM   #4
GTX JOHN
All we do on Stock Schubecks is adjust them so pushrods will barely turn with
dry fingers at right position on valve adjustment chart ....Then readjust them again with the engine warm the same way.
Awful simple minded but seem to work for me over the years....do make sure
the lifters are pumped up to top if they leak down as some soon do.......preoil engine again......repeat as required.
Old 07-25-2011, 05:42 PM   #5
Hans Olsson
Thank you for your help,John and Duane.
