Old 05-15-2007, 06:04 PM   #1
Jeff Lee
Guest
Posts: n/a
Default New dual 7" clutch - pictures dissassembled
For those that have not seen this new clutch assembly up close, check this out!
http://stangbangerz.com/umtr/yabb/Ya...num=1178850928
NHRA #7494 SS/H
1970 AMC AMX
"Best Appearing" @ NHRA '06 Pacific Sports Nationals
JeffLeeAzRealty@Qwest.net
602-418-9797
Old 05-17-2007, 09:38 AM   #2
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Default
Now to find some money and build some linkage!
Lee Norton
Performance Punch Embroidery Digitizing
Slowtime Motorsports
I/PS '02 Firebird 231 V6
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 05-17-2007, 03:46 PM   #3
Default
Nice piece, and worth more than my whole car!
(hot link)
Blue Streak Promotions
Old 05-17-2007, 06:32 PM   #4
seb
Default
Jeff:
What does that 'puppy' cost?
SEB
seb is offline   Reply With Quote
Old 05-18-2007, 01:25 AM   #5
Tom P
Liked 239 Times in 94 Posts
Default
At the SEMA show last year i was looking at a little race clutch used by "ricers" that make 1000hp in 3000lb cars. It was a billet aluminum diaphram hat and they had sintered iron as well as carbon fibre discs that were wafer thin and about 7" diameter (probably Metric size). The whole setup with a flywheel was lighter than my Soft Lok pressure plate which even has an aluminum pressure ring.
Old 05-18-2007, 03:23 AM   #6
Jeff Lee
Guest
Posts: n/a
Default
Rob get's $2900 for a standard dual 7" assembly. That's not bad when you consider his 10 single disk assembly sells for $2100.
NHRA #7494 SS/H
1970 AMC AMX
602-418-9797
Old 05-21-2007, 08:29 PM   #7
Jeff Lee
Guest
Posts: n/a
Default
Keep in mind that the diaghram clutches MAY be lighter in some applications but a diaghram, by design, is basically an on / off switch. Slippage off the line and between gear shifts does not occur. I think in this case it would be better to sacrafice weight in order to keep the engine at it's optimum power band. Agree?
NHRA #7494 SS/H
1970 AMC AMX
602-418-9797
