Old 07-31-2011, 12:58 PM   #11
Lonnie Cox
Wink Re: Converter recomendation
Lonny ,
I would want to know the duration @ .050 , how "good " the heads and intake are, and if you are using Shubeck style lifters and a lot of spring pressure. In other words, do you plan on revving it up?
My cam card reads
Gross valve lift int .391 exh .411
Dration @
.020 Tappet Lift int 281 exh 290
Valve timing open close
@ .050 int 20 btdc 54 abdc
exh 59 bbdc 25 atdc
These specs are for cam installed @ 107 intake center line
Duration @ .050 int 254 exh 264
Lobe Lift .2610 .2740
Lobe separation 107.0
Heads have Comp valve job
Springs Beehive 125lb @ 1.800,bronz guides,screw in studs , guide plates,manley ss 195/150 valves
Intake stock just block off egr.
Thanks for all your help.
Lonnie Cox is offline   Reply With Quote
Old 08-01-2011, 12:25 AM   #12
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default Re: Converter recomendation
WOW on the cam!
Old 08-01-2011, 12:45 AM   #13
Ed Wright
Ed Wright's Avatar
Originally Posted by greg fulk View Post
WOW on the cam!
Really!!
Ed Wright 4156 SS/JA
Old 08-01-2011, 08:46 AM   #14
Robert Simpson
Liked 20 Times in 12 Posts
Question Re: Converter recomendation
Really!!
Which part is wow?
Robert Simpson is offline   Reply With Quote
