Old 08-16-2011, 04:45 AM   #11
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: Oil Expander Ends - Positon/Phasing on Piston Important?
just throwin' this out there, way back when i re-rung a 400 IT yamaha and it had pins in the ring lands to keep the rings where ya put 'em....
Old 08-16-2011, 07:52 AM   #12
Ed Wright
Ed Wright's Avatar
Didn't want to snag a port in the cylinder wall with the end of a ring, right?
Ed Wright 4156 SS/JA
Old 08-16-2011, 07:56 AM   #13
Ed Wright
Ed Wright's Avatar
Originally Posted by Adger Smith View Post
GM spent millions trying to figure that one out. Remember the problems with 307 and 396 oil useage? Ring placement and rotation speed during break in was part of the problem. Some engines rotate the rings at a real slow rate, others faster. The method of placement GM found is now put in every Mahle/CP/Clevite ring box on a little green piece of paper. I could get Real Technical, but for time sake... Just use their little paper. It works.
I've never bought a set of those rings. Total Seal doesn't send that paper. :-)
It tells you how to stop them from moving? I'd like to see that. Do you know if it can be found on line?
Old 08-16-2011, 09:14 PM   #14
CraigG
Hey Guys,
Thanks for all your help!
It has been 10 years since I could save the money to build this motor.
Sorry - I have been working to use the best practice techniques I can and to check everything - but I have to be careful Not to get too ANAL or it will never get put together! LOL!
Thanks Again, Craig
CraigG is offline   Reply With Quote
Old 08-17-2011, 12:22 AM   #15
Adger Smith
Liked 880 Times in 311 Posts
Ed, They all move (rotate) except the ones that are pinned in place. The trick is to locate the rings where they will not rotate past one another during the early stages of break in. GM spent big bucks figuring out that problem. When they line up during break in it is a form of "hyd. lock". Where one ring won't rotate through the small oil path left by the other ring. After break in they will rotate past one another because the oil line, at the end gap, is reduced to nearly nothing. I'll try to scan the piece of paper with the placement in tomorrow night. I think there is something similar in the How to Hot Rod BB Chevies publication.
Adger Smith (Former SS)
Old 08-17-2011, 08:15 AM   #16
Ed Wright
Ed Wright's Avatar
Thanks Adger.
Old 08-17-2011, 05:36 PM   #17
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
From How to Hot Rod a Big Block
[IMG][/IMG]
Ron Gusack is offline   Reply With Quote
