Old 08-17-2011, 05:47 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Tire pressure
The shot below is at MIR with 9.5 pounds in a 32x14 on a 13" rim. I'm not sure exactly how far off the line it is, but I'd say at least 15-20 feet. Judging by the wrinkles, I think I need way more pressure. What should the tire look like this far out? Thanks for your help.[IMG][/IMG]
Ron Gusack is offline   Reply With Quote
Old 08-17-2011, 06:36 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,198 Times in 977 Posts
Default Re: Tire pressure
From the angle I can't tell how much roll you've got, any idea how much more loaded the Right side is? Also, car weighs about how much and how is it set up? 9.5 lbs sounds like plenty to me so other variables may be in play...
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-17-2011, 08:36 PM   #3
Ron Gusack
Ron Gusack's Avatar
Car weighs 2800 with 1220 in the rear. I've never scaled the car with individual scales. It's got a mono leaf with sliders and ladder bars that I pre load the right bar until it leaves straight. The back of the car is too high and I'm working on that. Here's a video of the car last Saturday. I know the burnout was too long.
Old 08-17-2011, 08:50 PM   #4
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Decals look nice on the car.
Doesn't matter what the tire looks like. Keep raising the tire pressure until it spins, then back it off. Run as much as you can get away with consistently. The car will work better on both ends of the race track, and you won't wear out the sidewalls on the tire so quickly.
Old 08-17-2011, 09:33 PM   #5
Ron Gusack
Ron Gusack's Avatar
Thanks Michael, I'm happy with the way they turned out. I have a few tiny air bubbles that seem to appear when it's really hot out. The company that prints them should spend an extra dollar and use a larger box instead of folding the decal. I'm trying to come up with a way to mount the vinyl from the inside to protect it when cleaning the lexan.
At MIR I think I could have run much more air and still hooked. I adjusted the shocks up a click, but never tried more air. Thanks for your input. Should I go up 1/2 lb at a time?
Old 08-17-2011, 10:50 PM   #6
Michael Beard
Throw 11-12psi in them and see if it sticks! Then baby steps.
Agree on the shipping boxes... sorry about that. I get them started, then pull taunt and squeegee. Typically, any small bubbles will disappear over time when exposed to the sun. Vinyl is somewhat permeable, and it'll 'suck fast' to the window. They are laminated, so they'll last.
Old 08-18-2011, 02:22 AM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Tire pressure
Stick a pin in the air bubble making an itty bitty pinhole and push the air out working it toward the pin hole. Works great for all sizes of bubbles. Jim
Old 08-18-2011, 07:37 AM   #8
Ron Gusack
Ron Gusack's Avatar
I thought about that Jim, but I thought rain/stuff would get in the little pin hole and eventually make things worse.
