Old 08-22-2011, 07:37 PM   #1
CraigG
Liked 8 Times in 7 Posts
Default Valve Leakage Check?
Hey Everybody,
I have E-heads with swirl polished valve, solid roller springs and multi-angle seats.
I tried windshield washer fluid and the inner springs installed without the spring pocket shims - the valves wept after a couple hours and puddled in the ports overnight.
Valid test? or is there a better way to check for leaks with the heads off?
Thanks Again, Craig
CraigG is offline   Reply With Quote
Old 08-22-2011, 09:43 PM   #2
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: Valve Leakage Check?
I don't know what E heads are, but I use vacuum, with a gauge, to test for leaks. I check mine with the full spring on.
Ron Gusack is offline   Reply With Quote
Old 08-23-2011, 08:28 AM   #3
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
On the car with a leak down tester is best. Off the car your going to get mixed results. Springs should be set as per race ready pressure, use Alcohol tinted with some color. If the valve is bent it will show almost right a way.
Bob Pagano A/SA
Old 08-23-2011, 08:33 PM   #4
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Yeah if it poors out as you fill I'd check the valves or the angles. Once the motor fires it's gonna seal up so that seepage should not cause any sleep loss
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 08-24-2011, 12:43 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
If you have them off Go ahead and face the valves. Every new set of E heads I get in the shop I face the valves. (for flow cut a small back angle on the intake) Very few of the new valves have acceptable runout. The face angles are always a little off. The seats always seem to be ok and don't need attention. If the heads are used do a good valve job on the seats. The heat cycles on new alum. heads always causes alittle movement in the seats. It is just normal and one of those things that happens to new alum heads. It is a bummer to have to face valves on brand new heads, but it is more of a bummer to put new heads on an engine that are leakers. It is just Std procedure, whether I furnish the new heads or the customer does.
Adger Smith (Former SS)
Old 08-25-2011, 04:20 PM   #6
CraigG
Smile Re: Valve Leakage Check?
Hey Everybody,
Thanks - You guys are always great and very helpful.
Take Care, Craig
