Old 08-23-2011, 04:39 PM   #1
CraigG
Liked 8 Times in 7 Posts
Default Lapping Compound?
Hey Everybody,
I have E-heads with swirl polished valve, solid roller springs and multi-angle seats.
What would be a good lapping compound - Brand, Grit, supplier for my application?
Engine book recommended 600 grit.
Thanks Again, Craig
CraigG is offline   Reply With Quote
Old 08-23-2011, 05:27 PM   #2
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: Lapping Compound?
Craig,
The Goodson Company has a large selection of valve lapping tools and compounds.Their depth of stock is AMAZING!
http://www.goodson.com/store/templat...0f4d0619e28305
You also might find lapping compound and other items at the local Sears!
Good hunting!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 08-23-2011, 06:55 PM   #3
richie 2
Liked 205 Times in 93 Posts
GOODSEN... #39401 is their 280 fine grit compound is very good. ( it's actually "CLOVER" brand by loctite) i have used it for years in the shop. they also have finer grit's avilable. auto parts stores stuff is like mud with salt added. nfg.
richie 2 is online now   Reply With Quote
Old 08-23-2011, 07:30 PM   #4
BillK
Liked 30 Times in 17 Posts
Craig,
It really depends on what you want to do with it. In reality, all that lapping compound should be used for is sort of a final check to make sure the valve is hitting the seat all the way around and in the correct place on the valve. It should not be used to actually remove any metal or make a bad seat "good". I also use the Clover compound. I use the 400 grit and get it from MSC, mainly because they are convenient and I am usually ordering something from them at least once a month. Goodson is also very good.
Bill Koustenis
BillK is offline   Reply With Quote
