Old 09-09-2011, 11:15 AM   #1
StockerRook
Default LT1 fuel injector size?
Got my motor all buttoned up and put in the car. The only thing i have left is figure out is which injectors i need to run.
Will the stock injectors work (24 lb. I think ?) or do i need to upgrade to a slightly larger injector (Around 30 lb.)
The car has a BS3 management system.
I apologize in advance for my lack of knowledge. Any help would be appreciated.
Chris
Just a couple pics of the painted engine bay.
ID:	9183   Click image for larger version
StockerRook is offline   Reply With Quote
Old 09-09-2011, 12:05 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: LT1 fuel injector size?
Chris
WOW big issue discussed a lot on LT1/LS1 and impalassforum.com.
The 24# injector seems to work well with 350's with just about any cam.
Fuel Pressure can be cranked to 55psi to meet demand.
I use a PCM and tune with LT1 Edit or TunerCat.
Some move up to 26# Injectors but most stick with the 24#er's.
30lb Injectors are used when our www.ECIRS.org racers move up to 383/396/409 LT1 engines and or power adders.
If you have a PCM and Laptop,
FreeScan is available to help tune the engine by recording a run.
I use a Walbro High Capacity Fuel Pump, far more than the car needs.
Infact may go back to the stock pump.
D
Old 09-09-2011, 01:12 PM   #3
MOTORSPORTS Innovations
MOTORSPORTS Innovations's Avatar
Liked 15 Times in 2 Posts
Chris - more info needed:
Are you running Speed Density or Alpha N?
What injector size is specified in BS3?
What fuel pressure are you using?
What injector size was used previously?
www.motorsportsinnovations.com
MOTORSPORTS Innovations is offline   Reply With Quote
Old 09-09-2011, 01:26 PM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I used 24 lb Accel injectors in my LT-1 Stocker.
I think the present owner upped them to 30lb'ers probably because the 24's were just about wide open at some parts of a run....
The 30's did not make any difference from what I can see performance wise....
Rich Biebel
S/C 1479
Stock 147R
Old 09-09-2011, 02:56 PM   #5
StockerRook
Motorsports Innovations,
The motor has never been started but I believe the Big Stuff Unit can operate in Speed Density OR Alpha N mode. Im not really sure of the difference between the two but initially I will prob use the mode which is easier to operate and tune. (I have zero experience with tuning a car and have much to learn). I dont believe a specific size injector is specified and I plan on running about 55 p.s.i of fuel pressure. Im using an A-1000 Aeromotive fuel pump with AN-10 lines so Im sure fuel delivery will not be an issue. I believe the stock injector size for this motor is 24 lb.
Thanks for the help to those have replied.
Old 09-09-2011, 08:58 PM   #6
Ed Wright
Ed Wright's Avatar
There are fast LT1 Stockers running 24 lbs and 30 lb injectors. Personally I would use the 24lbs at 60 psi. Higher pressure atomizes the fuel better.
As far as Alpha N or Speed Density, that has no influence on required injector size. And, you can select any size you want with FAST XFI or BS3. Just type in the size you have. Remember to correct that value if you up the fuel pressure as that increases the injector flow rate.
Ed Wright 4156 SS/JA
Old 09-09-2011, 09:07 PM   #7
magnumv8
Here is the formula for selecting the proper injector for your application.....
injector size = HP x BSFC (.5 avg) over number of injectors X duty cycle (80%)
in a normal V8 with 400 HP when you plug in the numbers you end up with 32 lb. injectors....
You want to be a little large rather than too small or even close so that the injector doesn't reach a saturation point where it literally doesn't close but stays open, that is why the duty cycle is at 80% in the formula to give you a little "head room"....
Normal fuel injection flow rates are @ 43 lbs......by pushing the fuel pressure up you can fool the system into "thinking" the injectors are bigger than they actually are, fuel atomization may be a little better with more pressure, but it is best to start conservative and slowly push things until you see if there is any increase in performance AFTER you get a good tune in the vehicle.....
D L Rambo.....
magnumv8 is offline   Reply With Quote
Old 09-09-2011, 09:24 PM   #8
Ed Wright
Ed Wright's Avatar
45 to 60 psi was worth 5 rwhp on my car after leaning it back to the same WOT air/fuel ratio. GM has been running many engines at 60 psi since at least 1996. Higher pressure doesn't make the computer "think" anything. Injector flow rate actually goes up. Many EFI racers have learned their cars repeat better when run closer to 100% duty cycle. I can't tell you why that is, but if you ask around that is a common story. High duty cycles won't cause failures at much less than ten second per run. 80% limit on duty cycles have not proven to mean much drag racing in the real world. Does sell injectors though.
