Old 09-21-2011, 11:27 AM   #31
rawhide
Liked 7 Times in 5 Posts
Default Re: CJ mustang engines
Originally Posted by Bill Harris View Post
The352 and 428 engines are old windsor SBF based pushrod motors which do use a conventional intake with a four barrel throttle body. The 281 is a mod-motor, overhead cam engine, but I think it uses the OEM style intake (composite/plastic?) with a newer style single hole TB.
Bill,
The 281 uses a dual bore throttle body. The part number is M-9926-3V and each bore is 62 mm and it is also available with mechinical linkage. Part number M-9926-3VM.
regards, Roland
rawhide is offline   Reply With Quote
