Old 09-23-2011, 06:31 PM   #1
rod
Liked 20 Times in 15 Posts
Default SBC block filling ?
i have a 60 over 327 to assemble. i would like to fill [hard block or?] this block to the bottom of the water pump holes. i understand you can put a plastic tube in the water jacket to use the lower block drain.
if anyone has personally done this, would you either explain here in detail or e-mail me.
also what brand is the best?
thanks rod in AZ
hugunin@frontiernet.net
rod is offline   Reply With Quote
Old 09-23-2011, 07:13 PM   #2
Liked 1,912 Times in 429 Posts
Default Re: SBC block filling ?
Of the commercially available block fillers, Hard Block is by far the best. I use Embeco 885 from White Cap Construction Supply, Darin Morgan of Reher and Morrison suggested it.
Yes, you can buy plastic tubing and stick it up through the drain holes. Some people just drill and tap the side of the block above the block filler, and drain it there.
Old 09-23-2011, 07:59 PM   #3
nolongerracing
Liked 72 Times in 27 Posts
I hope your not going to fill a "ready to assemble" block.
nolongerracing is offline   Reply With Quote
Old 09-23-2011, 11:49 PM   #4
rod
no, this block is still dirty. nothing done yet. however i do know a local guy who had his MoPar block all done and then filled it. sure messed up the cyl. walls.
i do like the idea of changing the placement of the drain. i thought about that. i wonder if i could braze a 1/2" to 3/8" pipe bushing on the side. the block is not of sufficient thickness to get more than one thread.
thoughts on this?
rod in AZ
Old 09-24-2011, 09:51 AM   #5
Reed Granrt
I am very sure that I did not say this, but You may want to consider rust stripping the block inside. If you pour the block with the rust layer that is there, you will set up 2 problems 1: the rust acts as a blockage to heat transfer out of the cylinders 2: You will have poor adhesion by the block filler. Make sure you de-acid with a acid that does not attack the base met. Only use acid that attacks the rust oxide. If you do not find out what that is, PM me and I can tell you (but I didn't tell you)
reed
Reed Granrt is offline   Reply With Quote
Old 09-24-2011, 01:06 PM   #6
Liked 5,145 Times in 1,964 Posts
thanks rod in AZ
If you fill to the bottom of the w/p holes, then you don't need block drains. The water will run right out the front. Just pull the lower hose.
Old 09-24-2011, 10:05 PM   #7
rod
that's correct mark. i have not thought all this through. rod
Old 09-24-2011, 10:21 PM   #8
pmrphil
Liked 348 Times in 152 Posts
filling the block to the WP holes will still require a drain - the filler is not level with the ground, it's at an angle and will leave water in the block at the outside edge. I have drilled and installed 1/8" NPT drain plugs, plenty of room for threads.
Phil Molski
PMR Performance
S/C 1623
Old 09-25-2011, 08:22 AM   #9
Ed Wright
Ed Wright's Avatar
Phill is correct. Drill and tap it for new drain plugs. It's thick enough.
Ed Wright 4156 SS/JA
Old 09-25-2011, 03:59 PM   #10
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
reed
Muriatic acid. Wash well and neutralize after.
