Old 10-11-2011, 07:15 AM   #1
ron b
Liked 4 Times in 4 Posts
Default gear ratio
i am running a 1968 mustang set up like a stock eliminator car. the car has a 428cj, pro shifted toploader and 4.56 rearend. the car ran a 10.85 at 127mph. do you guys think it would et better with say a 4.88 gear? thanks ron
ron b is offline   Reply With Quote
Old 10-11-2011, 09:57 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: gear ratio
Use formula to gear for rpm you want @ finish line MPH X Gear ratio X 336 divided by tire height=RPM
Mike Taylor 3601
Old 10-11-2011, 10:15 AM   #3
69Cobra
Liked 2 Times in 2 Posts
Mike Taylor 3601
^^^What he said^^^
But Yes you need a 4.88
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 10-11-2011, 08:37 PM   #4
1299
Liked 54 Times in 12 Posts
if you where to use radial tire or bis ply tire is it the same formula????
1299 is offline   Reply With Quote
Old 10-12-2011, 02:48 PM   #5
Mike Taylor 3601
you would change tire height in formula,if you were trying to get that precise,but I don't know how tell how much tire growth would happen, rim/tire width,mph, sidewall etc. would all have to be factored.
I always have just used height on sidewall or mearsured and is close enough,any growth that happens is just a little cushion that keeps you from going over.
I have always geared by this formula IE if want to go through @ 8K gear so I get as close to that # as can.
Mike Taylor 3601
