Old 10-16-2011, 07:55 PM   #1
63 savoy
63 savoy's Avatar
Question hemi race carbs
anyone have a fix for constantly changing float settings in the holley 4236 and 4235 hemi cross ram carbs --it seems as though they will not hold a setting--tried different floats , seats etc.stumped--Mike
63 savoy is offline   Reply With Quote
Old 10-16-2011, 09:26 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: hemi race carbs
Just a thought but I'm thinking too much fuel pressure or faulty needle and seats.
Old 10-17-2011, 02:10 AM   #3
Phillip marvetz
Phillip marvetz's Avatar
I've had the same problem, It's not fuel pressure related.
2009 V/SA Record Holder
Old 10-17-2011, 09:21 AM   #4
63 savoy
63 savoy's Avatar
got a return fuel system at 6 #----I wonder if the angles where the float touches the needle are not quite right---you set the floats, make a pass, and then there is fuel everyplace---almost like the floats are getting heavy---somebody must have the fix for this---Mike
Old 10-17-2011, 11:57 AM   #5
Ed Wright
Ed Wright's Avatar
How are you setting the floats? With the sight plug in the side? I don't know too many racers that do that. Take the bowls off, turn them upside down, and use a drill bit for a gauge between the top of the bowl and top of the float. Most use either a 3/8" or 7/16" bit for a gauge. I think if you do that, then recheck them later you will find the float level is not changing, but that you have other problems.
What do you mean "fuel everywhere"? Fuel sloshing out the vents? That is not a float level changing problem. Try a 7/16" dril bit first. If the carbs are set front-to-rear, not cross ways, you will probably want to use a 3/8" on the rear bowls.
Ed Wright 4156 SS/JA
Old 10-17-2011, 01:17 PM   #6
BlueOval Ralph
Banned
These carbs are not center pivot float bowls (the 3/8 drill is fine for center pivot bowls) the Hemi float bowls are the side pivot bowls ( just like the old 660's or the Ford Holleys for the 427's) for side pivots start with a 5/16ths drill.
Ralph
BlueOval Ralph is offline   Reply With Quote
Old 10-17-2011, 01:42 PM   #7
63 savoy
63 savoy's Avatar
Question Re: hemi race carbs
carbs are side hung 770 on hemi cross ram---they flood----set up is fuel(c 16) just dribbling out the sight holes with the engine running---seems like we have to constantly reset the floats--I see now why guys do not like to run these carbs---Mike
Old 10-17-2011, 02:41 PM   #8
FED 387
Liked 333 Times in 180 Posts
sent u a pm---FED387
Old 10-17-2011, 02:51 PM   #9
FED 387
sent u a 2nd PM this will fully explain what is happening---what is happening i is not what you think is happening !!! FED 387
Old 10-17-2011, 02:55 PM   #10
Ed Wright
Ed Wright's Avatar
Originally Posted by BlueOval Ralph View Post
These carbs are not center pivot float bowls (the 3/8 drill is fine for center pivot bowls) the Hemi float bowls are the side pivot bowls ( just like the old 660's or the Ford Hooleys for the 427's) for side pivots start with a 5/16ths drill.
Ralph
Sorry! I stand corrected.
