Old 10-26-2011, 12:18 PM   #21
Glenn Briglio
Glenn Briglio's Avatar
Liked 985 Times in 314 Posts
Default Re: Lifter ? sbc Hydraulic/stocker
Why is everybody trying to reinvent the wheel? Do the Smith lifters work? Yes they do and for the price of a new engine it's cheap insurance.
Old 10-26-2011, 01:13 PM   #22
ron mattson
Liked 69 Times in 32 Posts
Do Smith lifters work? yes they do, and they also fail occasionally and when they do
it costs you a new engine. The ceramic puck is like grinding compound when they
fail and break apart. It may not even be the lifters fault, you could break a rocker and
start the process, all i know is it costs a lot when it happens.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 10-26-2011, 01:37 PM   #23
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
This is just an exercise in futility............
I see on another post from Greg Hill that he has the inside scoop from Comp Cams that roller rockers will be legal next year...........
If that happens how far behind are roller lifters?????????????
The next step will be to remove the Stock Eliminator section from the NHRA Rule Book
Let me recap the events that killed Stock Eliminator.....
Removal of the OEM spring pressure & size rule
Removal of the cam duration rule & cams designed with lift rates to take advantage of the above change
Lifters designed to take advantage of the above
Roller rockers to take advantage of the above rule
How can roller lifters not be the next rule to take advantage of the above rule changes???
The last Stock rule change will be an additional S to make it SS
Bob Mulry 7516 STK
A & M Motorsports
Old 10-26-2011, 01:49 PM   #24
danny waters sr
danny waters sr's Avatar
Arrow Re: Lifter ? sbc Hydraulic/stocker
Boy !
I must have the stockest stocker out there cause i ain't got none of all these goodies.
Just plain ole ..Old school....No wonder my s@#t don't run...
Old 10-26-2011, 02:54 PM   #25
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Originally Posted by ron mattson View Post
It may not even be the lifters fault, you could break a rocker and start the process, all i know is it costs a lot when it happens.
Ron, I guess broken rockers will be a thing of the past.........
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 10-26-2011, 03:01 PM   #26
Liked 1,954 Times in 440 Posts
Yeah, next up, broken rocker studs .................................
Old 10-26-2011, 06:46 PM   #27
Rick Leininger Jr.
xx
Rick Leininger Jr. is offline   Reply With Quote
Old 10-26-2011, 06:52 PM   #28
Rick Leininger Jr.
xx
