Old 10-28-2011, 09:26 PM   #1
mcashman
Liked 6 Times in 3 Posts
Default ? about stocker pistons
In stock doses the piston need to have an nhra appovered stamp on it or just the correct part number from the apporved list?
mcashman is offline   Reply With Quote
Old 10-28-2011, 10:12 PM   #2
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
Default Re: ? about stocker pistons
As far as i know all it needs is the MFG. # from the list.
STK1217 is offline   Reply With Quote
Old 10-28-2011, 10:14 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
The Lunati's I bought had both, stamped into the face of the piston, "NHRA" and the part number. I'm not sure if every company does this, but I would bet that as long as the part number is on the approved list you should be good to go!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 10-28-2011, 10:44 PM   #4
Liked 1,953 Times in 439 Posts
My CP pistons did not have an NHRA approved stamp on them, just the NHRA accepted number. My JE pistons all have the NHRA logo on them. You can run all sorts of off the shelf pistons from various manufacturers, many of whom do not even make a special piston for Stock Eliminator. So you do not need any sort of special marking.
Old 10-29-2011, 01:45 AM   #5
Tom Moock
Liked 10 Times in 6 Posts
Alan, I think if you have an aftermarket piston, not stock piston, without approved nhra # stamped on it, they would have you pull a piston out of the motor. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 10-29-2011, 02:27 AM   #6
Tom, I was referring to a special marking, like the NHRA logo on my JE pistons.
For example, my CP pistons just had C4CP on them. That's the NHRA approved number. If you put a set of Speed Pro/Federal Mogul/TRW pistons in, so long as they had the correct part number, I don't think they'd need a special marking.
Old 10-29-2011, 10:50 AM   #7
mcashman
Thanks for the info guys.
