Old 10-28-2011, 12:06 PM   #61
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Roller Rockers in Stock
I don't mean to help jump the thread off-track, but I was at one of the F.A.S.T. (Factory Appearing Street Tire) races about a year ago at US-131 Dragway. I saw a couple of the cars running 130+ MPH on basically bald red lines, which is probably a recipe for disaster. The engine's looked stock, but internally were mechanical roller with 500+ cubic inches and sky high compression ratios.
Jim Kaekel 3836 STK
Old 10-28-2011, 01:26 PM   #62
Pat Cook
Little info from experience with roller rockers on a FE Ford stocker, back to back with "stock" rockers verse's Harland Sharp roller rockers, on the track.........= 0, nothing...I don't maybe I needed to change the jetting and timing and collector choke size and tire pressure and piston rings and .....to take advantage of the rollers.....I dunno....
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 10-28-2011, 06:19 PM   #63
Jeff Lee
Jeff Lee's Avatar
Originally Posted by Dean Feiock View Post
Jeff, If this rule is for real, I doubt you will see racers installing cast or extruded aluminum body rocker arms. And at the price you mentioned, that is what they will be buying.
Quality forged aluminum body rockers and high strength stainless body rockers have price tags much higher than that.
Another overlooked item is the fact that you cannot just throw on a new set of rockers and go. Undoubtedly the ratio will be slightly different, which means complete mock up and new pushrods if you land on the wrong side of the lift figure.
I wouldn't have a problem at all running Crane "Gold" at all. That was the standard in SS for decades before shaft rockers became the standard.
Jeff Lee 7494 D/S '70 AMX
Old 11-03-2011, 09:52 AM   #64
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
When will NHRA release the 2012 rules revision?
Larry Curtis is offline   Reply With Quote
Old 11-03-2011, 11:07 AM   #65
Liked 1,893 Times in 423 Posts
Probably at or after the PRI Show in Orlando in December.
Old 11-03-2011, 11:36 AM   #66
BlueOval Ralph
Banned
They usually have the new rule books at SEMA if you are one of the blessed ones!
BlueOval Ralph is offline   Reply With Quote
Old 11-04-2011, 02:16 PM   #67
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Thumbs up Re: Roller Rockers in Stock
Why are so many against this ?
There's no real performance advantage ( ok... 3 HP )
I for one, welcome this with open valve covers.
My engine will damage a stamped steel rocker on the intake side, about every 4 runs.
Last year, I put on a set of rollers, with intention of going to Edmonton ( IHRA )
Engine is absolutely trouble free since then.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 11-04-2011, 02:48 PM   #68
They did not this year.
Old 11-04-2011, 02:49 PM   #69
Jim Kaekel
I'm personally against because of the added expense to upgrade. I already spent a fair amount of money to get the stock stuff to work, and now they (NHRA) turn around and legalize roller rockers. To update my Olds, I'll have to get guide plates, screw-in studs and new hardened pushrods as well. Plus, it's just one step closer to Super Stock.
Jim Kaekel 3836 STK
Old 11-04-2011, 02:56 PM   #70
Aubrey, if you're damaging a stamped rocker every 3-4 runs, you have a serious problem, and the roller rockers are merely a band aid. How many passes do you have since the roller rockers were installed?
Do you have an old Chevrolet Power Manual? If you do, go back and read the section on valvetrain for the big block Chevy, since your valvetrain is very similar. Pay particular attention to the part about roller rockers and 7/16" rocker studs with high valvespring pressures.
I think we figured up we had about 500 passes on our original rockers when we replaced them. They did not have an insert welded in them, I polished the burr off of the pierced hole over the pushrod cup. We eventually wore the rockers out, the tips, balls and ball seats were just worn out. We ran near 550# open pressure, and turned 7700 or more in the lights every pass.
